Results 21 to 30 of 38
Thread: Setting up Serial WB to work with Auto VE tutorial.
  1. #21
    May 2015
    You were right I changed the B4205 table but forgot to Enable B3801
  2. #22
    Ok, good job on getting it going
    (sometimes can't see the forest for the trees... or is that supposed to be vice-versa...?)
  3. #23
    May 2015
    in this tuning world its vice versa haha. LTFT's are 3.9 and average BEN is .98 so for my first shot im happy with that. I have attached a log for confirmation of my happiness. Thanks again mate.
    maflessltft.efi
  4. #24
    Senior Member DocZ28's Avatar
    Mar 2007
    I haven´t try AutoVe until now, I did follow the tutorial and unplug the MAF, but when I try to start the engine it won´t start. Until I plug the MAF again, I Re-check the file and looks like is suppose to be.
    I must be missing something. Any advice?
  5. #25
    May 2015
    With the maf is it a 3 wire or 5 wire?
  6. #26
    Mar 2007
    3 wire, is a Camaro Gen III LSx
  7. #27
    May 2015
    Upload a copy of the tune file of you can.
  8. #28
    Mar 2007
    Here is the Tune
    Doc SD AutoVe_0000.ctz
  9. #29
    May 2015
    Will check it this arvo when I get to a computer.
  10. #30
    May 2015
    everything looks set up right in the tune, what has changed in the tutorial from what Joe has showed me is with B3605 leave this factory and change B3618 to 1.17. When you say the car wont start does it turnover and just not fire?
  1. Tutorial: FlashScan V2 Serial Wideband Logging
    By TAQuickness in forum Tutorials
    Last Post: July 22nd, 2015, 09:47 AM
  2. Replies: 6
    Last Post: April 21st, 2015, 03:13 PM
  3. Newb Setting up serial Wide band
    By HellKnightHicks in forum General
    Last Post: January 16th, 2013, 11:30 AM
  4. Auto VE With a Serial AFR
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: April 11th, 2011, 04:34 AM
  5. Setting up auto ve with serial input ???
    By Slowrc in forum Gen III V8 Specific
    Last Post: February 12th, 2010, 04:01 AM
