Results 1 to 10 of 19
Thread: Known issues with the December 2015 Public Stable-Release
    Default Known issues with the December 2015 Public Stable-Release
    Currently known issues and possible workarounds for the December 2015 Public Stable-Release of the EFILive Software and Firmware
    Download the public stable-release here: https://forum.efilive.com/showthread...Stable-Release
    Public pre-release software versions:
    • Software: V7.5.7.299
    • Software: V8.2.2.290
    • FlashScan/AutoCal firmware: V2.07.95
    Issue 1:
    Workaround:
    None.
    It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
    Apr 2012
    Seems that T43 os 24256125 is missing the adaptive volume and pressure presets. Trying to tune one now and don't have access to them. Also can not change os in t43 anymore apparently.
    Quote Originally Posted by dieselmd View Post
    I would appreciate these ones too myself. This is the 2011 model year. noticed they are mapped in the 2013 ones though.
    To give efilive a financial incentive i purchased the t43 stream :-)
    Apr 2012
    That os had these tables previously. Last update is when they disappeared.
    Nov 2005
    What software did you update from? I've reinstalled a range of software releases between March and December and all calz files have the same generation date.
    Cindy
    Apr 2012
    I'm not 100% sure Cindy. I would think it was a pre release from mid year'ish. Looks like last one I did with this os was around the end of October and I had the tables then.
    I see the 2016 T87 OS I've been waiting for...... VERY HAPPY NOW!!!!
    Thank you!
    Chuck CoW
    I just checked and I don't think that OS ever had those preset tables in there. Same applies for all OS's after this one (essentially 2011+), GM changed the strategy (going off memory here) and we never figured it out.
    Changing OS's must be done via V8, I don't think V7.5 could ever Full Flash the T43.
    We will take at look at those tables again but it probably won't be until next year.
    Apr 2012
    They were definitely there. I tuned one with that os just a couple months back that had to have those tables. All the other os', even newer ones, have them as well.
    I have tried to full flash in v8 and it tells me that there is an os mismatch. Never used to do that before.
    Dec 2005
    Hello Paul,
    I know I mentioned this in the past that Windows no matter what always wants to go online and look for a new Updated Driver every time I plug in a different Autocal for linking, etc.
    I got a new shipment in and using this new release it seems one out of every three will cause a rebooting failure, the progress bar just stops and hangs there and will not complete rebooting onscreen.
    If I close Control Panel and Close either Explorer or V8 Scan and Tune if its open it kills the rebooting hang.
    Anything I can try to resolve the issue ?
Name:	Autocal Firmware Update Reboot Hanging.jpg
    www.mscservices.net
  1. Known issues with the November 2015 Public Stable-Release
    Last Post: December 9th, 2015, 04:04 PM
  2. November 2015: EFILive Public Stable-Release
    Last Post: November 27th, 2015, 04:08 PM
  3. Known issues with June 02, 2015 Public Release
    Last Post: July 8th, 2015, 05:07 PM
  4. Known issues with May 01, 2015 Public Release
    Last Post: June 2nd, 2015, 10:46 AM
  5. Known issues with April 13, 2015 Public Release
    Last Post: April 30th, 2015, 08:33 AM
