Results 1 to 6 of 6
Thread: My DIY LT1 24X 411pcm upgrade.
    Dec 2015
    Default My DIY LT1 24X 411pcm upgrade.
    Hi guys.
    I'm doing a 24X conversion using a 411 PCM on my LT1 96 TransAm.
    I'm building the crank and cam reluctor wheels. I'm a machinist by trade so building the parts is the fun in it for me. I know I can buy everything I need to do the change over but I like making my own parts.
    The plan is to turbo charge the LT1 and tune it with EFILive.
    I have a LS1 on the engine stand and I have used a piston stop and degree wheel to find true TDC so I can see the relationship between the cam and crank reluctor wheels and sensors.
    One of my questions is if I miss the crank reluctor wheel to sensor alignment by a degree or 2 and I command
    20* of timing and my timing light shows 22* is there a place in the EFILive software to offset this so the commanded timing matches what I see with a timing light?
    Or should I build in some adjustment into the sensor bracket?
    Quote Originally Posted by LT1 View Post
    I don't see any place for such an offset.
    This may be of interest to you (I don't know what the timing was):
Name:	CKP CMP waveform relationship.png
    Dec 2015
    Thanks for posting that, very valuable info.
    I will build in some adjustment so my commanded timing matches what my light shows, that's easy to do.
    As fare as the accuracy of the 1X cam signal is concerned in relation to the 24x crank signal I can't see it being very critical.
    If it were people couldn't degree there cams and motors with high mileage with badly worn timing chains would set codes and not run very well. I've owned a few trucks with 300K+ miles that ran great. I know GM has a "target" to set off the cam sensor in relation to the crank but there are so many things that change the relationship the target window must be quite large.
    If I'm missing something please feel free point me in the right direction.
    Jul 2003
    I would do the 58x E38/E67. you get better idle quality and a faster ECU .... if you are going to do this, might as well do that...
    Dec 2015
    Those ECM's are defiantly upgrades over the 411 unit. I have a couple of reasonse for going the 411 route.
    I didn't want to tackle the DBW throttle body on my first time with tuning a factory ECM. I'm sure I'll have my fair share of bugs just changing over the LT1. The other reason in my son owns a stock 02 Z/28. If I get to lost I can plug up to his car and compare things.
  1. LT1 24x Conversion - No knock retard, ever.
    By jahajazz in forum Gen III V8 Specific
    Last Post: June 6th, 2018, 04:10 PM
  2. in search of someone with 24X LT1 experience.
    By bustahiman in forum General (Petrol, Gas, Ethanol)
    Last Post: November 30th, 2015, 05:18 AM
  3. 24x SBC and LT1 Conversions with both CKP and CMP in Timing Cover
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: December 18th, 2013, 04:48 AM
  4. EFI Connection "24x" System and LS1 PCM for LT1/LT4 Engines
    Last Post: May 26th, 2009, 01:54 PM
  5. EFI Connection 24x Electronic TPI/LT1 Drive-by-Wire Throttle Bodies
    Last Post: May 26th, 2009, 01:52 PM
