Results 1 to 9 of 9
Thread: LML Cruise control intermittant after flashing
    May 2008
    Default LML Cruise control intermittant after flashing
    Hi Guys,
    Have just flashed an 11 lml with a tune , tunes great but now, the cruise cuts out intermittently
    and most time it cuts out you can hear the abs pump cycle. Initially ( cold this morning) it
    actually flashed the stability control yellow warning light at the same time for a second.
    After that I did a full yaw sensor relearn etc and now its not flashing the light but you can see on
    the scan tool it cycles the abs pump as it kicks out of cruise. have checked all the sensor outputs
    on the scan tool making sure nothing is turning it off, wheel speeds are all the same , but it still does it , mostly just once within two
    minutes of startup then seems to work fine after that. Any ideas?
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Post the tune and post your vin... I'll look it over for ya if you want. You can post stock file you used-not necessarily tune file.
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    May 2008
    So apparently the original tune I used (third party supplied) was incorrect, the correct tune has now been supplied but the symptoms remain, erratic activation of the esc .causing the cruise to cut out abs to apply (mostly left side from the logs ) . the vin is 1GC2KYC82BZ200332 and they have used a 1254094 file. ( wouldn't mind a copy of a stock one if some one has it). I'm wondering if when updated to the 4094 software the esc software hasn't got left behind? open to ideas.....
    Nov 2009
    Quote Originally Posted by shane View Post
    Who were the tunes from originally?
    -Kory
    May 2008
    PPEI supplied the tune. is it possible to swap an ECU from a known good truck of the same model , or are they vin number locked to the bcm? so how would I unlock it?
    It may not be the tune , although that's all we have done to this truck. swapping ECUs would prove it once and for all , ive wasted two full days on this now grrrr
    Nov 2009
    I own PPEI, I'm sure we sent the right one.
    If you modified any parameters in the speed limit section def/Dpf speed limits, put those back stock.
    -Kory
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Log steering angle (degrees) vs. yaw rate (deg/sec) vs. lateral acceleration (g/sec) with a Tech 2. (or MDI or whatever, EFILive wont access the ABS module)
    Drive in a straight line and note when you get an ESC event, the scan tool should say "VSES active", see if any of the above parameters go wonky for a second while driving in a straight line.
    I really cant see the wrong ECM calibration causing inadvertent/erratic ESC events. I think you might have a problem with the steering wheel position sensor and/or yaw-lat sensor. Ive heard of some LML's having issues with the SWPS when cold
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Aug 2008
    Quote Originally Posted by Dmaxink View Post
    That's what I'm thinking as well.
    Nov 2009
    For that vin... you should have speedo/system segment 5023/5005.... If thats what you have- then the issue will not be in the base file, but rather the tuning you did within the base file.
    -Kory
  1. cruise control P0571
    By DURAtotheMAX in forum General
    Last Post: April 14th, 2015, 01:21 AM
  2. LML Flashing Support
    By cindy@efilive in forum Duramax 2011+ LML / LGH
    Last Post: August 2nd, 2013, 09:56 AM
  3. Lean Cruise and Cruise Control
    By neil in forum Tuning For Economy
    Last Post: July 9th, 2007, 08:42 PM
