i had a set of heads put on a couple weeks ago and noticed that the car had been running rich(plugs, valves, and pistons all black) so i bought efilive and when i read my current tune my previous tuner had set my pe vs rmp from 3600rpm and up 10.8afr so i leaned it to 12.2 but the problem is that it slowed the car down and was not getting anymore kr so does anyone know why i would be loosing power with the car leaned(but probably still to rich)i switched between my old tune and the new(only thing changed was the pe) at the track and mph was down w the new tune, also my o2's are reading 930mv with the old tune and 880mv with the new tune i put on, but like i said it seemed it was making more power rich, also i made multiple runs both ways but the car seems like it is running slower than it should both ways best on motor was 12.1 and nitrous 10.9 at 125 any help would be appreciated
cam is 222/228 566/571 113lsa
heads are ported ls6
4l60e trans
255lph pump
ls6 intake
