Results 1 to 10 of 15
Thread: More torque
    Jul 2005
    Default More torque
    C'mon guys this is driving me nucking futs. I have all this torque management showing up at idle and decel. It doesn't seem to affect spark and it doesn't operate as advertised, doesn't total as stated in Pid "More info". BTM doesn't respond to settings in B0401 and B0402. Operator error or program fluke? Using the GM.EST_*_DMA Pids. COS 2030003, 1 bar
    Y2K C5, M6, LS6 intake, Kooks LT headers, High flow cats, 216/224 113 LSA, 5.3 Stage II heads. STS twins. COS
    Is your brake switch staying on...?
    Check this by scanning the STATExx or TSTATExx pids.
    Jul 2005
    e
    No, that's the first thing I checked. Cecked with cruise control. Can't figure why the pids aren't summing in TRQ_DMA. Do you know what EST stands for?
    EST = Electronic Spark Timing
    Jul 2005
    Thanks. My line of thinking was simplistic, like this is estimated timing that gets pulled if torque was activated.
    Everything is primarily active at 0 throttle, idle and DFCO, any increase in throttle and the torque management subsides. Just ran a 20 minute log, see what I can find.
    Post a pic of the latest log when you get a chance.
    I was looking over some wire diagrams, and I noticed that some cars have upto 3 brake switches (one for PCM, one for CC, one for elsewhere...), but I couldn't tell if the CC was disengaged from the switch going to the PCM or the one going to the CC; it may be a good idea to log some of the STATE or TSTATE pids just in case.
    Jul 2005
    Missing about 3 deg of timing on this WOT, don't know were it went. Inlaws at the door. I'll see if I can sneak in a run/log to the store later. I think the BTM is for autos, but I can't turn it off. XMSN and BTM pids read identical almost all the time.
    Jul 2005
    Just logged numerous state pids, everything is OK. Brake switches including extended and stoplamp switch work just fine. Clutch switches are Ok. Back to the drwng board.
    DFCO shows to be inactive, but judging by the rumble/popping in my exhaust when I slow down it sure isn't.
    Now my volitile memory shows failure, wonder what the hell that is.
    Quote Originally Posted by purrvert
    You get a DTC...?
    Jul 2005
    You get a DTC...?
    Only P0103, self inflicted.
  1. So I am logging torque...
    Last Post: July 13th, 2009, 04:23 PM
  2. Torque!
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 19th, 2008, 01:11 PM
  3. Torque management, TCS, TCS fast torque loss
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: October 2nd, 2006, 05:16 AM
  4. Torque Convertor?
    By Bradazz in forum General (Petrol, Gas, Ethanol)
    Last Post: June 7th, 2006, 03:10 PM
  5. Max torque range?
    By technical in forum General (Petrol, Gas, Ethanol)
    Last Post: May 31st, 2006, 03:35 AM
