Results 1 to 4 of 4
Thread: Innovative Wide Band issues
    Dec 2015
    Default Innovative Wide Band issues
    Hey all
    Recently bought EFI Live, still working it all out.
    Current problem is i have an innovative AFR gauge, i can get this gauge accurately reading AFR in 7.5 scan tool via the v2 FLashscan so im confident im on the right track, however i cannot get it to work on the flashscan alone - it just doesn't seem to register. I have the same PIDs running on the flashscan and in 7.5 (except i had to upload them to the v2 in v8) and the gauge is hooked into the orange 5v port on the bottom of the flashscan. Cant see any settings in that would explain this in the V2, the innovate device settings are all accurate (LC1, AFR, Innovate brand etc)
    Any thoughts?
    Do you see the AD1 voltage pid on you V2 LCD...?
    ( with BBL, calc pids aren't logged in real time, they are added after the log )
    Which V7 and V8 build versions are you using (did you install from the forum software section...?)...?
    Dec 2015
    Yes, i can see the AD1 voltage setting in data logging. Display W02 just says not found and w02afr1 always reads 25, though the last part was the same in efilive and i think its not a relevant pid
    v8.2.2 build 290 and 7.5.7 build 299
    Your saying perhaps they should not be working until after the log is made?
    I have AD1, AFR_LC11, BEN_1 and W02AFR1 PIDs loaded
    Dec 2015
    Went for a drive and did a log, sure enough the afr is all working in the log, just not real time. Cheers!
  1. I need help with my wide band
    By isak81 in forum External A/D inputs
    Last Post: January 8th, 2012, 03:46 PM
  2. Innovative MTX-L wide band O2
    By scottcmb in forum Gen IV V8 Specific
    Last Post: October 28th, 2011, 09:16 PM
  3. wide band issues
    By smslyguy in forum Gen III V8 Specific
    Last Post: September 1st, 2009, 01:13 AM
  4. Wide band
    By Harrismarine in forum FlashScan V2
    Last Post: July 6th, 2008, 12:27 PM
  5. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 04:19 PM
