Results 11 to 20 of 21
Thread: DSP5 CAN Messages.
  1. #11
    Yeah for new hardware a discrete VPW bus<> CPU interface and software VPW emulation in the CPU, a lot harder for sure but it means we never get caught with supply issues.
    From what I know of the ELM it is pretty cool for a lot of comms stuff, but I don't think it would have the 'grunt' to be used for CAN programming applications where blocks of 2048 bytes are sent up at once.
  2. #12
    Lifetime Member Chavez91's Avatar
    Dec 2012
    Sounds like a solid plan.
    Yeah, for my small projects the ELM has done alright. Just looking for more things to tinker with as I get bored.
    The DSP switching seemed like something fun to learn. Just wasn't sure if it was some top secret thing or not.
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
  3. #13
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    Josh, you can use an ELM327, couple fast-acting NPN and PNP transistors, some schottky diodes and a few resistors to easily interface an ELM327, STN1100, or ELM322 to J1850 VPW. It works fine for doing things like cluster/DIC messages, controlling things like door locks and other modules, and DSP-switching on 01-05.
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
  4. #14
    Nov 2005
    bit-banging VPW, I bet that was fun to code LOL!!
    Yeah the ELM322/ELM327/STN1100 probably wouldnt be suited to reprogramming or high speed logging, because it only supports standard 10.4k regular communications mode, it doesnt support 41.6k VPW high speed mode I dont think.
    12.9s @ 108 mph
  5. #15
    Nov 2005
    We don't use ELM chips in our hardware, the Infineon CPU we are currently using in V2/AC has a VPW processing module built in (which is one of the main reasons we picked it), the hard chips to get are the 8 pin IC's that connect the VPW bus to the CPU (I don't recall the actual Freescale part number of it).
    Phillips/NXP AU5780A is what you're referring to. I think they might be available on Alibaba as chinese knockoffs/leftovers, but I havent been able to find a legit source for "real" ones yet.
    The good news is you can effectively do the same thing as the AU5780A chip with resistors, transistors, diodes, and a +8v linear regulator. Its just annoying because it makes your circuit much bigger and more complicated. And then you have to add your own external EMC/transient protection as well.
    Its really obnoxious that VPW transceivers have completely disappeared. I know its not used anymore in new automotive applications, but forcing end-of-lifecycle on a chip as widely used as the AU5780A after only 5 years or so is ridiculous IMO.
    12.9s @ 108 mph
  6. #16
    Nov 2005
    Josh- Heres a schematic I drew up for a simple VPW interface circuit. It works fine. Its similar to the circuit that ELM suggests, but I had to add a couple extra components to make it more reliable.
    Some of the resistor values might have to be changed slightly to work with 5v versus 3.3v. But try it as-is first. At your own risk of course.
    12.9s @ 108 mph
  7. #17
    Dec 2012
    Quote Originally Posted by DURAtotheMAX View Post
    Yeah, the ELM doesn't support VPW4x. Just 10.4k as you said.
    Josh
    '04 GMC LLY
  8. #18
    Dec 2012
    Thanks, Ill try that one out also with the STN1110. 3.3v would be nicer as well instead of the 5v.
    Josh
    '04 GMC LLY
  9. #19
    Dec 2012
    Looks like the ELM only supports 8bytes for transmitting. Doesn't support block mode transmits or 4x. Not sure if that could pose a problem. Not sure if the STN1110 or 1170 do either? I read that they have the 4x capability but wasn't implemented in the firmware? Do you know that answer Ben?
    Josh
    '04 GMC LLY
  10. #20
    Nov 2005
    All databus messages, whether its CAN or J1850VPW, they're all 8-byte max.
    Well, 8 bytes plus header. For J1850 the header is 3-bytes long. Priority, target node, source node.
    The ELM327/322, and STN1110 chips will do everything you want to do as far as DSP switching. The only thing they wont do is high speed 4x logging and reflashing.
    12.9s @ 108 mph
  1. KOEO messages??????
    By rfinn04 in forum Duramax 2011+ LML / LGH
    Last Post: September 13th, 2015, 06:07 AM
  2. Can anyone help me decode these two messages
    By slow-poke in forum General
    Last Post: August 7th, 2014, 06:30 AM
  3. Error messages while recording
    By eboggs_jkvl in forum General
    Last Post: June 11th, 2010, 08:03 AM
  4. Warning messages in DVT
    By MyM8V8 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 29th, 2010, 08:56 AM
