Results 1 to 4 of 4
Thread: Balence rates
    New Member dainmeyero's Avatar
    Jan 2016
    Default Balence rates
    Can't seam to figure out how to get the scan tool to work on my lap top ,in trying to check my balance rates on my 2010 lmm. Can anyone give me some pointers or walk me through it please!
    New Member 02_ramair_ta's Avatar
    Sep 2013
    Would also like to know... I'm new
    Dec 2013
    I'm another one working on this with EFILive and V2 flashScan. Just need a proceedure I think I've found the PIDs.
    Dec 2013
    OK, I think I'm on a roll. I've not tried the pass through system yet but I've figured out how to get the balance rates on to the V8 scan and tune screen on the lap top. I loaded the PIDs into the FSV2 then warned up the truck and did a BBL in recording mode. I logged 5 minutes at normal running temp and idle speed. I then went inside and removed the SD card from the FSV2 and loaded up on my lap top. I double clicked the automatically save log file on the SD card and then the V8 scan and tune app opened I chose the data window and the file had to be configured, took a minute or so but it came up as a chart that showed the average balance rate and the high and low rate for all 8 cylinders. If I could figure out how to attach a pic I would. Any suggestions? It's getting late now and I'm hesitating to add more. I realize this a fairly old thread so if anyone is that interested I'd be glad to add more detail.
    08 Silverado LTZ 2500HD Black CCLB, 4" DP back Diamond Eye Exhaust with stock muffler, AD 150 lift pump, EFI Live V2 w/ Idaho Rob DSP5 tunes, 60 Gal. Texas fuel & tool w/HM xfer. Dragin' a 32ft Crossroads Cruiser 5er and Hyde drift boat or ATVs when in AZ. Calling card: Ramblin River Rats
  1. injector return rates
    By crash85 in forum Duramax LLY
    Last Post: August 6th, 2015, 04:01 AM
  2. Fuel Injector Rates
    By 12_Square in forum Gen III V8 Specific
    Last Post: January 16th, 2014, 08:29 AM
  3. Fuel Balance Rates?
    By cummins2500_07 in forum Cummins 5.9L
    Last Post: October 23rd, 2013, 07:45 AM
  4. injector balance rates
    By Hunter t in forum Diesel
    Last Post: June 11th, 2012, 12:38 PM
  5. Balance rates
    By diesel freak 123 in forum Duramax LB7
    Last Post: April 22nd, 2008, 02:55 PM
