Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Trans not following tune
    Nov 2015
    Default Trans not following tune
    So I'm using a CSP based tune. I have doubled checked to make sure I am on the right tune. I am running on tune #4. I have modified the 3-4 shift point and in the base tune I have modified the TCC for 3rd lock. For some reason it's not following my tune, it still shifts whenever it wants and it's not locking up in third like I want. I attached two logs and the tune. Any ideas?
    CMB_0012.efi
    CMB_0013.efi
    CSP5 tune hi_idle 06_07_0000.ctz
    Lifetime Member Move'n Up's Avatar
    Oct 2015
    Do you have a custom valve body or kit in it because I do not believe the stock assembly is capable of 3rd gear TC Lock?
    2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
    Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
    2017 Corvette 3LZ Z06 M7 with Z07 Package
    Nov 2015
    Quote Originally Posted by Move'n Up View Post
    Stock transmission, but am pretty darn sure it will lock in 3rd as I can tell when it does in T/H mode and can get it to do it in regular mode also before it hits 4th if I'm careful. Even if we forget about the TCC, why is it shifting to 4th so soon? In the tune I have it not to shift till TOS reach 2100 @ 30% throttle and 2000 @ 20% throttle. I'm holding just slightly higher than 30% throttle and its shifting into fourth around ~1750ish I believe.
    Now 2nd gear I'm not so sure about. I've read many say it will not, but when I have logged the truck and while in second gear, TP% same, TOS and MPH gradually climb, you can see the rpm drop and then start climbing again while everything else is consistent. That makes me think the TCC will lock in 2nd on stock VB. I'm still unsure though. I think you can see it in these logs actually.
    Oct 2015
    Correct, I'm thinking about 2nd gear lockup in a stock trans which isn't possible . Sorry my bad :-D
    3rd will lock if O/D is turned off in certain situations.
    TOS is a key item to factor in so your on the right track.
    I'm at the office so I can't see your tune to provide any feedback
    Nov 2015
    See if these help.
Name:	3_4 upshift throttle.png
Name:	log 3_4 upshift.png
    Senior Member tylerltr450's Avatar
    Aug 2014
    Did you increase pressure?
    2006 Cummins Red, Auto to Nv5600, SBC 3600, Traction Bars, Visor, Running Lights, S&B Intake, ATS intake horn, EFI Live, Borg Warner S363 Turbo, Industrial Injection Dragon Fly Injectors.
    Nov 2015
    Quote Originally Posted by tylerltr450 View Post
    No, the only thing I adjusted was the TOS vs throttle. I'm just focusing on the 3-4 shift right now and getting 3 to lock TCC sooner.
    Aug 2014
    Quote Originally Posted by Ghostman View Post
    thats what I figured but I just wanted to double check and make sure that your tb is closing quick enough and not causing a guessing game.
    Nov 2015
    I've gone back through everything and can't figure out why its shifting to 4 so soon....
    Nov 2015
    Anyone got any ideas? Anything else I could post to help?
  1. Need a stock tune for 06 manual trans
    By protraxrptr17 in forum Cummins 5.9L
    Last Post: February 15th, 2013, 01:30 PM
  2. 6l90e built trans tune?
    By 600+duramax in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 20th, 2011, 10:53 PM
  3. How do you tune the Trans using efi
    By johnj in forum General (Diesel)
    Last Post: March 12th, 2011, 12:10 AM
  4. help with trans tune
    By skycrane in forum Vortec V6/V8 Specific
    Last Post: October 16th, 2009, 05:16 AM
  5. Cant Tune Trans?
    By uwyo_dmax in forum General (Diesel)
    Last Post: November 12th, 2008, 06:18 AM
