Results 1 to 5 of 5
Thread: Updated firmware and now V2 unable to find vehicle
    Senior Member Naf's Avatar
    Aug 2006
    Default Updated firmware and now V2 unable to find vehicle
    I upgraded my firmware to the newest version dated dec 11, 2015 and now i am unable to use my V2 to datalog alone or even with the laptop. Yesterday i was able to flash one tune, but today i am unable to do anything.
    What could i do to get it all to work again?
    I have a 2005 CTS-v where i swapped the PCM for a E67. The harness was nearly plug and play and i also added extra terminals to the obdii port so everything may communicate.
    I thought it would be the cable, so i tried it on my E38 and it worked flawlessly. Something happened and i cant figure it out.
    American Muscle, European Design, Japanese Tactics
    Aug 2006
    ecu was toast, swapped it out and i now have communication with ECU
    Any idea what caused the ECM to fail...?
    Aug 2006
    I found arc marks near the positive terminal. I feel the battery charger could have slipped and arced before fallin on the carpet. I am using an alu bracket to hold the batt in place as well as the ecu. I may have to get a plastic case for the ecu.
    Just FYI, EFILive will replace the ECM's VIN license free of charge if/when you replace your ECM. To obtain your free replacement VIN license, email a copy of the replacement ECM's receipt to me at paul@efilive.com.
  1. Updated V2 firmware now error 0333
    By TrendSetter in forum FlashScan V2
    Last Post: October 5th, 2015, 12:01 PM
  2. Updated firmware and now cannot get into 7.5
    By Phone Man in forum AutoCal
    Last Post: October 4th, 2014, 02:04 PM
  3. Replies: 9
    Last Post: November 1st, 2012, 06:45 PM
  4. Replies: 4
    Last Post: November 29th, 2010, 02:04 PM
