Results 1 to 10 of 10
Thread: Scan tool Link and EDA Problems
    Jan 2013
    Default Scan tool Link and EDA Problems
    Im having problems getting the scan tool custom map to show the correct values in the table when reading a log file. I will highlight the cells with the log but the value that is in the cell it not correct. I have followed the link scan tool tutorial and verified that i have everything set up correctly but it still shows the wrong values in the cells. I have a map set for main injection duration and it will show in the cells 109 when it is really running 2800us. I dont know what im doing wrong with this. Also is it possible to use EDA parameters in the v7.5 scan tool i can never get it to work it always says that the parameters are not supported but the EDA parameters work perfectly in V8. Also when will we be able to use the live scan option in V8 on the CMB ECM?
    Nov 2015
    I didn't have very good luck using v7.5 except with the maps. But I also wasn't using eda pids either. Maybe try without eda pids?
    Nov 2015
    Ok well I tried using EDA pids to make a "map" in V7.5 and it worked for me.
Name:	v7.5 eda pid map.png
    This has main timing as the data with mm3 on top and rpm down side on a 20 minute log.
    Jan 2013
    Quote Originally Posted by Ghostman View Post
    I can't even get the eda pid group to load in 7.5. It just says it's not supported. It works great in v8 but just not in v7.5
    Nov 2015
    You mean like when you try to open the scan file that's what it says? I open 7.5 and then open the file. I think all I have is eda pids on this scan file
    Jan 2013
    Yeah either when I open a log file that was logged with EDA PID's it says the EDA PID's are not supported as well as if i try and live log it says the same thing.
    Nov 2015
    You have the latest software versions?
    Jan 2013
    yes, i am going to uninstall it and re-install it tonight
    Jan 2013
    It seems to work with a log file but no matter what i try to do for live logging with it connected to the truck it will not pull up EDA PID's
    Nov 2015
    Quote Originally Posted by rammegacab View Post
    Ok, I haven't tried live logging at all so I can't comment on that any.
  1. cant link scan tool to tune tool?
    By hpi_jeep in forum Cummins 6.7L
    Last Post: October 14th, 2013, 06:05 PM
  2. Problems with scan tool
    By monkeybrain in forum Cummins 5.9L
    Last Post: June 13th, 2012, 01:23 PM
  3. Friend with V2 having scan tool problems..
    By nonnieselman in forum FlashScan V2
    Last Post: June 6th, 2012, 01:02 PM
  4. Looking for Paul, scan tool problems.
    By 06bowtie_guy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2007, 12:28 PM
