Results 1 to 10 of 11
Thread: V2 Licensing Questions
    Junior Member clubby5000i's Avatar
    Jul 2007
    Default V2 Licensing Questions
    Hi all,
    if I reorder from the store, I notice it retains the old Authorisation code from the previous purchase. I normally change this the new code, but do I have to do that? I don;t want to forget and screw up a purchase.
    Also, if I purchase a stream license (E38 or LS1B), am I still limited to 220 VIN's in the V2 in total?
    Thanks in advance
    You should generate a new auth code each time you order.
    Once you have a stream licence then any subsequent ECMs that use the stream license do not use a VIN slot and are not counted in the 221 limit.
    Jul 2007
    Awesome! Thanks Paul. efiLive has awesome support and response times
    Especially when Paul is 'supposed' to be on holidays at the moment
    Need official EFILive help, please go here.
    For tuning support please post your questions on this forum (or other auto forums).
    Sorry if I don't respond to your PM, don't take it personal.
    Jul 2007
    Lifetime Member wesam's Avatar
    May 2010
    What should i do when i reach the limit of 220 Licenses ?
    I'm @215 now !!
    EFILive Tuner
    Dec 2005
    Buy another V2 and load it up with streams !!!!
    www.mscservices.net
    Either purchase streams for the supported controllers or purchase another V2.
    Quote Originally Posted by wesam View Post
    I'm @215 now !!
    There is a discount when purchasing a replacement FlashScan if/when you run out of VIN slots. Contact sales@efilive.com for more info on the discount and how to obtain it. If/when you do order a replacement make sure you specify your current V2 license number. The replacement V2 will be set up with the same license number before it is shipped to you.
    Sep 2017
    As a efilive newbe and getting ready to buy a GM V2, will I be able to pull in a base config/tune and use it to learn the software without burning one of the VIN as long as I don't write it back to the ECM? I just want to learn where everything is on the screens/pages. I have done some tuning in the past with other software but not the efilive.
    Regards Don...
    1952 Dodge Pilot House Gen III V8
    1949 Chevy Panel Van Gen III V8
  1. V2 Licensing between two different V2's?
    By dave w in forum FlashScan V2
    Last Post: September 30th, 2013, 10:44 AM
  2. Licensing
    By kistlerjm9 in forum Gen III V8 Specific
    Last Post: August 5th, 2009, 12:13 PM
  3. Licensing?
    By Mort in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2009, 03:06 AM
