Results 1 to 4 of 4
Thread: E38 BBX limitations
    Mar 2007
    Default E38 BBX limitations
    Just starting to work on an E38 ECM and noticed that you can log quite a few more bytes than the old LS1B's. I'm pretty sure the limitation for the LS1B is 24 bytes. In V8 Scan and Tune - BBX - it shows 42 bytes for the E38. I know that if you add more bytes to your PID list, then the logging speed goes down.
    Am I reading it correctly that I can have 42 bytes for the E38, or should I stick with 24 bytes?
    I don't have the figures/times with me right now but yes the CAN based controllers will log more data and log it faster than the VPW controllers.
    Mar 2007
    Does anyone have a comparison for logging speeds? I seem to remember that for the LS1B, 24 bytes of PIDs comes across at ~10 frames / second. I was wondering if for the E38, 42 bytes of PIDs translated to ~10 frames / second, of if it was even faster. Or maybe if I kept it down to say 24 bytes, that it would be xx frames / second???
    V7 can log 24 pid channel from an E38 at 40 frames/second.
    V8/V2 would be able to log 42 pid channels at 40 frames/second as far as I can tell.
  1. Do I need CSP5 to BBx
    By Ghostman in forum Cummins 5.9L
    Last Post: December 24th, 2015, 03:51 PM
  2. ?Lml flashscan v2 or autocal? Limitations?
    By bighuey in forum FlashScan V2
    Last Post: April 14th, 2015, 03:48 AM
  3. Help with bbx
    By restless@westnet.com.au in forum Black Box Logging
    Last Post: May 27th, 2013, 04:48 PM
  4. 06 duramax bbx help
    By rodder55 in forum Black Box Logging
    Last Post: June 12th, 2012, 09:49 PM
