Results 1 to 4 of 4
Thread: Error $0541
    Aug 2006
    Default Error $0541
    I am getting the error $0541 when I use my V2. I have only tried it on 2 licensed LS1b PCMs and I get the error on both. Also -- maybe unrelated. All of my .ctz files show up looking like a "Notepad" file instead of having the EFILive logo on them. I have the newest software and firmware on my laptop and V2 unit (V7.5.7.299) (V8.2.2.290) V2 bootblock is (2.07.07) V2 firmware is (2.07.95)
    Jeff
Name:	ctz vs tun logo.png
ID:	19154   Click image for larger version.
Name:	Error $0541.png
    Lifetime Member Move'n Up's Avatar
    Oct 2015
    I recommend reinstalling the EFI Live Software. You have a Windows file association problem at a minimum.
    2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
    Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
    2017 Corvette 3LZ Z06 M7 with Z07 Package
    Try doing a full flash using V7 pass thru flashing and checking the "Flash Recovery" option (I think that's what it's called). The problem is caused by corrupt NVRAM area in the PCM. That option attempts to fix it. If it's too corrupted then it may not be able to be recovered.
    Yes the icon is unrelated. Right click on a ctz file in Windows Explorer and select "open with..." Then select "choose..." And choose Efilive Scan and Tune. Check the "always use this application" option.
    Aug 2006
    Thank You Guys,
    I did the "Open With" and it was set to "Notepad". I'm not sure how I managed that, but I did.
    The weird thing is that the same PCM will flash fine with an older .ctz but a few of the newer .ctz that I try to put in it are corrupt somehow. I think this weekend I will uninstall the software and reinstall it and update it.
    Jeff
  1. Replies: 8
    Last Post: March 20th, 2018, 06:47 AM
  2. code $0541 now wants me to license again?
    By loganlewis in forum Gen III V8 Specific
    Last Post: March 24th, 2014, 03:29 PM
  3. I can't use V8 because of this error
    By odd boy in forum FlashScan V2
    Last Post: October 2nd, 2013, 08:56 AM
  4. ERROR. Please help
    By ntrimm in forum FlashScan V2
    Last Post: March 29th, 2009, 03:22 PM
  5. Com Error
    By Neilb in forum EFILive V4
    Last Post: January 6th, 2006, 06:57 PM
