Results 1 to 4 of 4
Thread: lb7 / 4l80
    Jan 2011
    Default lb7 / 4l80
    Hello there,
    Since the LB7 and 5.3/6.0 etc use a similar pcm can i swap in a transmission segment?
    Mar 2009
    Quote Originally Posted by derkscustomcars View Post
    Hello there,
    The ECM looks simliar on the outside, but thats where it ends. They share virtually nothing in common with each other internally. You can go with a manual trans calibration in the LB7 ECM, and then run a stand-alone, but I'm not aware of any factory combo that will work together fully integrated.
    Jan 2011
    Thanks. I just quickly glanced over the pinout of the ecm. Looked kinda similar. I'll have to do some digging. Do you know if a T42 will communicate with that ecm? Or do they only support the newer can bus?
    Mar 2009
    The T42 diesel CAL only talks in high speed GM LAN, so it won't talk in language that the LB7 J1939 can understand last I checked. DURATOTHEMAX would no ALOT more than I do on it as he speaks data coms. The stand-alone method has worked for many though.
  1. flashing for 4l80
    By akafred in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 16th, 2020, 11:07 AM
  2. LB7 with standalone 4L80
    By DURAtotheMAX in forum Duramax LB7
    Last Post: August 7th, 2014, 01:07 PM
  3. 01 LB7 PCM in 04 LB7 truck?
    By KLUG'S SS in forum Duramax LB7
    Last Post: December 26th, 2013, 02:25 AM
  4. 4L80 wiring
    By ebayer5 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 6th, 2009, 12:24 AM
  5. 4L80 question
    By Dirk Diggler in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 12th, 2006, 01:17 AM
