Results 1 to 5 of 5
Thread: Turning off Injectors (cylinders) to find miss. Please Help!
    Jun 2012
    Red face Turning off Injectors (cylinders) to find miss. Please Help!
    I have a 2006 LBZ. It developed a knock and started missing (running rough). When I turn off cylinders with EFI Live it makes no change in Engine at all except when I turn off Cylinder 4 which causes engine to run smooth. This was opposite to what I expected. When I had my shop and repaired gas engines in the pre computer days I had a SnapOn Diagnostic Tool that would cut out cylinders and when you cut out the bad cylinder there would be no change to the engine RPM and when you cut out a working cylinder the RPM would decrease and the engine would miss even more.
    Please help me find my bad injector.
    Thanks, Ricky Smith
    Oct 2014
    did you figure it out?
    Jun 2012
    Default Figured it out
    Quote Originally Posted by kajon25 View Post
    Yes but not with $1000 program and laptop. I changed the injector that made the least change in RPM when individual cylinders were killed and miss and knock was still present. I took my $5 Harbor Freight stethoscope and listened to each cylinder by touching stethoscope to the head close to each injector. The cylinder with the bad injector had a noticeable knock.
    Changed that injector... problem cured.
    This probably means the cylinders are mis-numbered in EFILive.
    Oct 2014
    Is this a possibility? I have come across this topic a few times and I always thought that since the cylinder order is different (starting at the passenger side front for number 1) that it was a user mistake.
  1. E38, FI, boost, cylinders cutting out. Help!
    By arubenstein in forum E37, E38 & E67 PFI ECM's
    Last Post: December 31st, 2014, 02:55 PM
  2. Large misfire count on cylinders 4 and 7
    By bubba68ss in forum Gen III V8 Specific
    Last Post: November 15th, 2014, 05:38 AM
  3. Cylinders filling with fuel!
    By camar0corey in forum Gen III V8 Specific
    Last Post: October 2nd, 2011, 10:38 AM
  4. Can you log knock for individual cylinders?
    Last Post: March 9th, 2008, 02:13 PM
  5. 2-3 cylinders down.Any answers?
    By SVR in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2005, 04:12 AM
