Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Cos3 01270003 to Cos 5 02020005. Wont start now
    Nov 2014
    Quote Originally Posted by 69camaro5speed View Post
    superstepside did you get this fixed if not I may have your fix ?
    I have seen this before, its a easy fix
    No I never did, just stuck with the COS3.
    Nov 2016
    SuperStepside: Was curious as to what the potential fix to this was. Was gonna look at doing the exact same thing but not if there's going to be a "not sure" problem with going to cos5.
    Dec 2005
    Quote Originally Posted by SuperStepside View Post
    Try this adjustments to see if it starts this should help.
    Guessing you have a 2 bar map sensor If not you need to change your scale
    also guessing your injector info is correct
    do a full flash and see how it does
    I have has some where it does not fault the maf meter right away and they will act like that.
    Your setting on MAF Diagnostics could of made it take a while to kick it to sd.
    If you have no maf on the car it will some times not start because its reading the first line of the maf and does not give you enough fuel to start.
    so if you bring up the bottom area of the maf some it gives you more fuel for starting so it can run enough to fault maf and run
    I Have seen this many times even with maf setting to 1 some times they will not start ....
    Dec 2005
    Quote Originally Posted by MurderMitten View Post
    Murdermitten co 5 works great I have used it 1xx times na ,boosted and nos cars It rocks
    Nov 2014
    Still havent gotten around to trying cos 5 again. Yea I made sure that the tables were the same between the cos3 and 5. Running speed density. Ill have to try this when I get the chance. Thanks for the help.
    That's a good trick to know
    Jul 2003
    This is because it is not setting up the code for the Mass Air. All these cars crank in SD. If your P010x doesn't set quick enough this will happen.
    Yes, without a MAF DTC the ECM reads the MAF, so bringing up the MAF low cells gives you more fuel to allow starting.
  9. #19
    Dec 2005
    That is what I seen on the 03 04 stuff a lot i have done a lot of off road buggys where they shut the master power off all the time so this help when dfc gets reset every time other wise you some times (depending on couple things) will pull your hair out working on them
  10. #20
  1. Brutally hard start after reflash - COS3
    By tirefryin_s10 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 26th, 2015, 03:38 AM
  2. Wont start now.
    By GM-OOD in forum Duramax LLY
    Last Post: July 10th, 2012, 11:37 AM
  3. Lean cold start COS3.
    By onfire in forum Custom Operating Systems
    Last Post: July 18th, 2009, 02:10 AM
  4. 02 Yukon COS 02020005, Reduced power light, No Start
    By genericuserid in forum Gen III V8 Specific
    Last Post: June 4th, 2009, 01:32 AM
  5. car wont start with COS#5
    By articSS in forum Custom Operating Systems
    Last Post: September 19th, 2007, 12:43 PM
