Hi,
when I connect my V2 for tuning or scanning, the dashboard does not work, AC works and cant be switched off. It is updated to the latest firmware (2.07.95) & Boot block (2.07.07)
Please help
Hi,
Please help
Regards,
Odd Boy
All GM 2007+ cars (you can say E38 Ones)
Regards,
Odd Boy
When scanning/logging or when flashing/reading, the other modules on the CANLAN bus don't get immediate bus access and/or immediate response from the ECM, so they complain.
You may have to remove battery power and let the modules discharge, and then reconnect battery power and let the modules sync up among themselves.
I have another unit, it works perfect. By the way, when I disconnect the unit "whenever I encounter a failure" the car goes back to normal
Regards,
Odd Boy
Odd Boy, are both V2's Blue or is one a Black? Is it the same OBD-II cable from the V2?
both are blue but different cable. I can swap and get you the result today...
Regards,
Odd Boy
I connected a brand new wire, the same thing happens..... please try to help as soon as possible.
Regards,
Odd Boy
