Results 1 to 10 of 15
Thread: DIfferent T43 question, can't change OS?
    May 2012
    Default DIfferent T43 question, can't change OS?
    Can't full flash? Error $0540
    Error $0540 means "incompatible OS"... i.e. you can't change to that OS.
    May 2012
    I understand that part but shouldn't I be able to full flash it right over top?
    Quote Originally Posted by 02CCSB View Post
    I don't follow...
    you're trying to flash that OS into your T43...
    the error code means that OS is not compatible with your T43...
    let me verify this, I'll get back to you...
    what OS are you trying to flash...?
    what year/model/vehicle is the T43...?
    During a cal flash the operating system number of the controller must match (or be a custom version of) the operating system number of the calibration being flashed, otherwise error $0540 will occur.
    Error $0540 is also used to indicate a mismatched operating system during a full-flash. A mismatched operating system is one that may not operate correctly with the controller's built-in, boot block software. The following list shows which T43 operating systems are compatible and can be interchanged during a full-flash.
    All OS numbers on the same line are interchangeable, if two OS numbers are on different lines then they cannot be interchanged.
    24237276,24237685,24239353,24240291,24248859,24243 170
    24244551,24249042,24253414,24249179,24251030,24249 833
    24247961,24256093
    24252573,24254909,24256025,24257135,24256065
    24256125,24257238
    24261871,24264142,24264923
    24265260
    24264497,24267577,24270599
    24257301
    24267571
    24268005
    Dec 2014
    24247961,24256093
    24256125,24257238
    24265260
    24257301
    24267571
    24268005
    Do you happen to have this broken down by year?
    Aug 2010
    Quote Originally Posted by Team208Motorsports View Post
    The OS changed with the model year on some controllers. With the T43, this relationship is not consistent. Some OS were used for only one year. Some OS were used for two consecutive years. Some OS were used for four consecutive years. With the T43, it is more accurate to reference compatibility with the OS itself, not the corresponding model year(s).
    Dec 2014
    Quote Originally Posted by Taz View Post
    Awesome, thank you!
    Dec 2008
    24247961,24256093
    24256125,24257238
    24265260
    24257301
    24267571
    24268005
    If the service number is the same on both TCMs, can you use TIS to flash the OS in that is not on the corresponding compatible line?
    Quote Originally Posted by roughneck427 View Post
    In theory yes because if you ordered a new TCM then whatever year model range it supports you could get TIS to flash that OS in.
  1. T43/E38 6L90 Shift points change
    By 55chevdelray in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 16th, 2020, 09:58 PM
  2. Arbitration ID question...T43
    By koryenger in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 26th, 2014, 09:11 AM
  3. Tire change for track question
    By SSThunder in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2007, 02:14 AM
  4. quick gear change question
    Last Post: August 9th, 2006, 09:24 AM
