Results 1 to 5 of 5
Thread: Tachometer tables?
    Mar 2009
    Question Tachometer tables?
    Would it be possible to add in the tach tables like the gasser ECM's have? I'm looking to do a cluster swap in my BURB to an ESCALADE cluster, and it requires a V8 tach signal(4 pulses per rev). I currently use an alternator driven tach in my stock cluster, but if I switch over I would like to use the LB7's stock LS style output, but to do so would require a tach adapter to double the tach signal pulses. Trying to do this without a tach adapter if at all possible. The tables I'm looking at are labled G1204, G1205, and B5402 in the 0411 ECM.
    I know the ones you mean on the 0411 PCM, I can have a look but we can't assume the Duramax ECM actually has such a cal. The LB7 code was written by Isuzu, not GM like the LS1 was.
    Mar 2009
    If you could it would be greatly appreciated.
    Apr 2013
    I would be interested in these as well. I've got a conversion truck I need to correct the tach with. I'm using the ESS signal wire from the lb7 ECM straight to the tach. Correcting the tach would be far easier and less expensive if we could use efi to do it.
    Nov 2005
    Quote Originally Posted by weazel View Post
    LLY calibrations were last updated in October 2008, almost 8 years ago. The amount of time our developer would need to spend to get back up to speed on that controller, then see if the calibrations existed, followed by internal testing and beta testing to ensure the calibrations continued to operate correctly would make the task not viable for 2 requests in 8 years, sorry.
    Cheers
    Cindy
  1. E40 throttle pedal tables cruise tables
    By 04colyZQ8 in forum Gen IV V8 Specific
    Last Post: August 28th, 2014, 06:10 PM
  2. Tachometer calibration
    By Russell in forum Duramax LB7
    Last Post: May 8th, 2012, 04:13 AM
  3. Which pin on E38 for Tachometer?
    By GAMEOVER in forum E37, E38 & E67 PFI ECM's
    Last Post: April 1st, 2011, 03:27 PM
  4. EFI LIVE Tables vs HPT Tables
    By TIM Z in forum General
    Last Post: January 18th, 2011, 09:42 PM
  5. Tachometer Issue after Motor Swap
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: November 8th, 2007, 05:42 PM
