Hi there i am looking for some help on how to remove maf from the map
it is a 2009 vxr 8
thank you
it is a 2009 vxr 8
thank you
For P0101,2,3: set those in C6001 to Non-Emissions, and set those in C6002 to No-MIL.
Then physically remove MAF (keep IAT if IAT is integral with MAF, i.e. use a discrete IAT sensor).
When you start engine, you should see a MAF DTC immediately.
You may have to correct the VVE table.
