Results 1 to 7 of 7
Thread: Pid for fuel psi ls3 and ls2
    Feb 2015
    Default Pid for fuel psi ls3 and ls2
    I've searched and I cannot find a pid. Cars I'm working on are 2010 Camaro Ss and 06 Gto. Any ideas? Software and firmware are current..
    Aug 2010
    I don't believe that either of those vehicles is equipped with a Fuel Pressure Sensor - that could measure the fuel pressure at the fuel rail.
    Perhaps you were thinking that this is the function of the Fuel Tank Pressure Sensor. It is not. The Fuel Tank Pressure Sensor is part of the EVAP System.
    Rail pressure is assumed to be constant at 58 +/- 1 psi.
    Feb 2015
    Ok, no way of knowing without installing a gauge than? Thanks!
    Feb 2015
    Quote Originally Posted by Taz View Post
    Is there any pids to monitor this? Seems that people on Camaro 5 using sct or hpt are able to log tank pressure or line pressure by the tank. Otherwise I've considered installing an autometer cobalt 0-5v fuel psi gauge and making a calc pid for logging purposes
    Lifetime Member Road's Avatar
    Feb 2015
    Quote Originally Posted by camaro10 View Post
    There is no sensor for a pid to monitor. Tank pressure is a part of the evap system and has nothing to do with line pressure. About the only ones that have fuel pressure sensors are direct injection and then you have a low and high pressure sensor to log. You can rig up a 0-5 volt sensor for logging but I don't see much to gain from it. I would connect a manual gauge and simply check if you have a pressure or supply issue. I am assuming you are referring to a LS3/L99.
    Feb 2015
    No none known but I'm looking into going centri blower.
  1. Bad fuel economy on ls3 headed ls2
    By TrendSetter in forum Gen III V8 Specific
    Last Post: August 4th, 2013, 10:38 PM
  2. LS3 Heads & Intake onto LS2/6.0 block.
    By Sid447 in forum Gen IV V8 Specific
    Last Post: July 12th, 2011, 12:09 AM
  3. tuning an LS3 on an LS2 ECM
    By LeftLane in forum Gen IV V8 Specific
    Last Post: August 1st, 2010, 01:30 AM
  4. SLP L92/LS3 package for LS2
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: August 17th, 2009, 09:11 AM
  5. do injectors have an effect on fuel psi?
    By mr.prick in forum Gen III V8 Specific
    Last Post: June 6th, 2008, 03:25 AM
