Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Vehicle Speedo correction issues E38/T43
  1. #21
    Sep 2010
    So i got my vy ute running with the 6l80e and looks like i got the same problem. however i can change the ppl value in the dash from the stock 6200 to 3000 and it bumps it up the speed closer to ecu speed.
    I'm just going to try something in the tune to see if i can get it closer.
    From memory changing HO 0150 to 203 started things on the right path for me
    Its all spot on now
    Let me know how you go and I can send tune
  2. #22
    Quote Originally Posted by Hooter View Post
    Its all spot on now
    Yeah i read that, but it screwed with your ecu vss didnt it? i guess at the end of the day as long as the tcm vss reads correct. shouldnt make a diff to what the ecu see's.
  3. #23
    So i changed H0105 to 182
    H0122 to 8
    Modified the PPK value in my dash cluster to 3000 as that is the lowest it will let me input. If i could change it to 2600 i'd be much easier.
    Now the TCM reports 100kph. ECU - 120~122 ish.
    Dash Cluster matches TCM speed
    That's with a 3.73 diff gear, I'll be changing to a 3.08 after the new year.
  1. Speedo Correction Confusion
    By pezboy in forum General (Petrol, Gas, Ethanol)
    Last Post: September 9th, 2014, 02:07 PM
  2. E6500 speedo correction
    By 06megatuned in forum Cummins 5.9L
    Last Post: February 7th, 2014, 07:35 PM
  3. Need 2010 T43 SPEEDO support across the board....
    By Chuck CoW in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: August 8th, 2010, 12:17 PM
  4. Speedo Correction
    Last Post: April 8th, 2007, 08:46 PM
