So here's a little run down of what I'm working on. I have a 2007 C6 Z06 that came to me in somewhat pieces as the factory engine harness was all hacked up, a Holley HP Engine Management was half way installed along with incomplete fuel system wiring, AMS 2000 Boost Controller half way installed etc. The car has a RHS 427 with a DPT Twin Turbo Kit, Powerglide / 9inch IRS conversion, Fore Innovations Fuel System with 3 fuel pumps, and the list goes on. I'm being told this has been an on going project for some time and the customer at this point just wants to see the car fire before really moving towards 100% completion. The customer would like to run a factory ECM and not the Holley system.
I installed a brand new GM Engine Harness in the car and attempted to read the Tune. I received an error message saying that the Tune was locked with a Key. After checking the boxes Try Alt Keys, Assume lock is faulty, try additional unlock strategies boxes, I was able to read out the Tune. The OS matches a 2010 SS Camaro OS and obviously not the original ECM from the vehicle. The Calibration also shows N/A.
My question is can I fire this car with this current ECM? Or am I just shooting in the dark? Attached is the current file that's in the ECM. Since The ECM shows to be for a 6L80E I still need to wire in the neutral safety switch. Since the current goal is just to fire and see the car Idle I wired one of the fuel pumps on a external relay and can turn on manually.
Any advice would be greatly appreciated. Thanks!
-Matt-
