Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Vin Problems
    Jan 2016
    Default Vin Problems
    Hey everyone. I have a 2005 ls1 computer that we've been trying to swap the vin over in. We have tried in both the tuner and the scanner both with no luck. The rest of the info in the tune flashes fine, except the vin, that always reverts back. Both in the tuner and the scanner. We even swapped os and still same thing. One thing we found odd is there was no counter for key off that is generated in the scanner when you change it....is that normal? Any help much appreciated.
    Aug 2010
    What is the Service Number on the PCM ?
    What OS are you working with ?
    Are you trying to enter a non-GM VIN ?
    Has the PCM ever been flashed with other software ?
    Jan 2016
    The service number is 12589463 . The os is 05120002 now, before it was 12592618. I am trying to enter a infinity vin into it, and yes we have flashed it with hp tuners in the past.
    Aug 2010
    OK ... that is a 2005 PCM and a 2005 COS - so that should be good.
    HPT doesn't usually shred the VIN or other module data (some other softwares may) - so that should be good.
    Does the Infinity VIN feature the same number of characters as the GM VIN ? (have no idea about Infinity products). If not, you may have to try using a leading zero(s) as placeholders - if the Infinity VIN has fewer characters than the GM VIN. If the Infinity VIN has more characters than the GM VIN - then this will not work at all.
    Jan 2016
    They both have 17 characters
    Aug 2010
    OK ... I have never tried what you are attempting, so I'm not 100% sure if it will work.
    Connect your V2 to the vehicle, and your laptop. Turn the vehicle ignition key to the "Run" position. Open the latest version of your tune using the V7 software. Click on the "Configure PCM locking and/or perform VATS relink" icon near the top of the screen. When the sub-menu opens - select the LS1-B PCM from the drop-down menu - then click the "Check status" button. Then select the VIN tab. Follow the prompts to change the VIN. You may get a pop-up message regarding the Check Digit being incorrect. Once the VIN has been changed - turn the ignition off for 1 minute (the instructions may state for at least 30 seconds).
    Do what Taz said, and copy/paste the text log so we can see what it did.
    Jan 2016
    Tried that a few times already but just tried it again for shits and giggles....same. no change.
    Jan 2016
    11:08:52.968: Scanning for EFILive FlashScan V2 HAPI
    11:08:52.978: Autodetect interface ...
    11:08:53.088: Interface firmware version: 2.7.82
    11:08:53.098: Connection to [FSV2] interface is OK
    11:08:53.098: CAN-VPW Bridge Activated
    11:08:53.158: Current protocol set to: "SAE J1850 VPW"
    11:08:53.158: Autodetect PCM...
    11:08:53.208: Connection to PCM is OK
    11:08:53.208: Current protocol: "SAE J1850 VPW"
    11:08:53.318: USB driver version: 2.8.40
    11:08:53.318: USB library version: 3.2.7
    11:08:53.318: Interface firmware model: FSV2
    11:08:53.328: Interface firmware version: 2.7.82
    11:08:53.338: Interface firmware date: Apr 10, 2015
    11:08:53.338: FlashScan serial number: 005000564132
    11:08:53.348: FlashScan license number: 005000564132
    11:08:53.498: Getting status...
    11:08:53.528: Status: OK.
    11:08:53.528: Request VIN...
    11:08:53.628: VIN: 1GCEK19B55E174764
    11:08:54.108: Request serial number...
    11:08:54.178: Serial number: 0NA0ABJ84296
    11:08:54.648: Request operating system...
    11:08:54.678: Operating system: 5120002
    11:08:55.098: Request GM BCC...
    11:08:55.118: GM BCC: MOD2
    11:08:55.538: Request GM VAT/IGN Cycles...
    11:08:55.558: GM VAT/IGN cycles: 0
    11:08:55.988: Analysing security...
    11:08:56.008: PCM seed is: $36B1
    11:08:56.008: Unlock attempt 1 of 1
    11:08:56.128: Security analysis complete.
    11:08:56.128: Ready
    11:10:31.233: PCM seed is: $36B1
    11:10:31.243: Unlock attempt 1 of 1
    11:10:31.363: Clear emisison related DTCs...
    11:10:31.383: Clear DTCs for all modules...
    11:10:31.913: Update VIN...
    Here is the data from the tuner log
    Aug 2010
    In the VIN / BCC tab ... make sure the both the "Clear DTCs" box and "Send Seed/key" box are unchecked (i.e. no check mark).
  1. changing vin on lmm to my suburban vin. is this doable?
    By Madspeed in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 24th, 2015, 02:14 AM
  2. Need a VIN
    By jnjprfrmnc in forum General (Petrol, Gas, Ethanol)
    Last Post: September 28th, 2009, 12:48 PM
  3. RR Blanked (000000000000) VIN Problems
    By JezzaB in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 27th, 2008, 10:10 AM
  4. what vin do i use the ecm vin or the dash vin
    By nycblazer in forum General (Petrol, Gas, Ethanol)
    Last Post: March 23rd, 2008, 03:31 AM
  5. Vin # in tune does not show the same as my vin...
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: February 11th, 2007, 09:04 AM
