Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
Thread: Maximum Timing For Stock Engine
  1. #11
    Aug 2008
    Quote Originally Posted by EverydayDiesel View Post
    It does but the original question is how much is the max % of timing i can safely apply to a stock engine
    Maximum timing is going to be relative to rpm and pulse. I am normally 45 to 50 max at say 3250 rpm and full pulse. One person already commented I am wrong. Let's see what his advice is then. I don't jniw everything for sure but have not had a single issue with that timing scenario. You are going to find very limited pointers on tuning.
  2. #12
    Nov 2010
    Quote Originally Posted by S Phinney View Post
    Perhaps you should re-read my comment.
    Right/wrong was not assigned....
    If you want help...its best to give specific data in which your asking help with.
    Your 1/2 way there with a 3250rpm window....as "Full Pulse" isint a useful datapoint in which to enter into a calculator....
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  3. #13
    Nov 2010
    As for the "Very Limited Pointers"...most have spent hundreds of hours, if not thousands on getting tuning right....
    Simply asking what is safe, isint going to render a useful answer as the info you ask for is again retaliative to the values your specifically using in your specific application...there is no "One size fits all" when it comes to timing...
    Les Szmidt
    2007 5.9 Dodge Ram
  4. #14
    Aug 2008
    Quote Originally Posted by 2007 5.9 View Post
    The op had a specific question of what is the maximum percentage of timing to safely run?
  5. #15
    Aug 2008
    One size fits all surely doesn't work. It is a varying timing percentage. The term safe is also relative to many variables.
  6. #16
    Nov 2010
    Without data like rpm and pulse...there is not a answer to give.
    Les Szmidt
    2007 5.9 Dodge Ram
  7. #17
    Nov 2010
    Lets use this for example....most people would pick a max of say 30* of timing to run on any given "Stock" application...and lets say that person went with the standard 3200uS "Max Effort" pulsewidth, and their RPM swing was from 2600-3500rpm...this is how a 50% split would look....
    RPM US ATDC BTDC
    2600 3200 25 -24.92
    2800 3200 27 -26.76
    3000 3200 29 -28.60
    3200 3200 31.5 -29.94
    3500 3200 37.2 -30.00
    Now running much past 30*ATDC is not going to produce any power, simply heat...which too much heat over time will infact start to erode the bowl lip and cause deformation.
    So as you can see that once you get close to pushing RPM, the importance of proper timing becomes very easy to see...
    Most tuners would never touch 30*ATDC in any application.
    Les Szmidt
    2007 5.9 Dodge Ram
  8. #18
    Senior Member KhakiCummins's Avatar
    Sep 2011
    RPM US ATDC BTDC
    2600 3200 25 -24.92
    2800 3200 27 -26.76
    3000 3200 29 -28.60
    Not to thread jack but Les, in the example you gave, is 3200 US just too much pulse to run above 3200 RPM because that is going to put you out of the bowl on both the leading and trailer edge? Is this the point where you would want to step up to larger injectors (assuming you have the other supporting hardware) so that you can shorten your pulse back so that you stay within that +/- 30° window?
    Duane
    2008 Ram 3500 QuadCab
    Hamilton 110# Springs & HD Pushrods, ARP 2000s, EFILive, SB 3250 DD
  9. #19
    Nov 2010
    Quote Originally Posted by KhakiCummins View Post
    FWIW I have never and will never suggest anything over 3000uS as a safe pulse to run...in my production environment, I generally don't go over 2900uS...if i have to use that to hit a target HP, I tell the customer to buy bigger injectors.
    As you can see as the RPM increases the injection window decreases...for a stock RPM truck its ok...but start getting into the 3500, 4000, 5000, and 6000rpm areas and man....the window gets VERY small.
    And there is no reason to stick to 30* as a max...in fact most high performance tunes I build are in excess of 30* over xxxxRPM...
    For a small reference, my personal truck...1000hp single turbo...2300uS max pulse...runs 35*@3500rpm and goes up from there..Im in the mid 40's over 4000rpm
    Les Szmidt
    2007 5.9 Dodge Ram
  10. #20
    Sep 2011
    Thanks for the reply Les. I know that there are a ton of variables and different situations but I was looking at it from more of a general theory perspective to better understand what some of the indicators are for a street truck as to when I should look at bigger injectors. If I ever get to that point.
    Duane
  1. auto VVE for stock engine ! ?
    By Ls1_Rulz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 3rd, 2013, 09:34 AM
  2. Not getting maximum duration?
    By 2006Cummins in forum Cummins 5.9L
    Last Post: January 5th, 2012, 10:31 AM
  3. Looking for some data from a stock engine log
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: June 24th, 2008, 04:14 AM
  4. Maximum VSS value?
    By jsttry in forum General
    Last Post: December 30th, 2006, 11:42 PM
  5. Tuning a stock engine...Worth it?
    By CGTMS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2006, 11:21 AM
