Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Maximum Timing For Stock Engine
  1. #21
    Nov 2010
    I wouldn't go over 3000uS....ever
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
  2. #22
    Jan 2016
    Maybe I should rephrase the question.
    I have a base tune and I am looking to increase timing. How do I know when I have increased it too much?
  3. #23
    Aug 2008
    It will get noisey and possibly excessive smoke. Timing is relative to the rpm and pulse at that moment. Have you ran what you have through the calculator to see where you are at with timing now?
  4. #24
    Nov 2010
    Quote Originally Posted by EverydayDiesel View Post
    I'll redesign my answer...
    What pulse and rpm are you looking at info for?
    Les Szmidt
    2007 5.9 Dodge Ram
  5. #25
    Jan 2016
    Quote Originally Posted by S Phinney View Post
    I just got efi live. Is there a guide on how to do this?
  6. #26
    Aug 2008
    No there isn't really much instruction. It will take you a enormous amount of time to learn the dos and don't s. Take it slow with small adjustments on one item at a time to find the correlations between various components of the tune. There are many limiters within the tune as well. Learn how they work and what they do first.
  7. #27
    Jan 2016
    Quote Originally Posted by 2007 5.9 View Post
    I am by bo means trying to be smart with the above comment. When I tune lsx engines I will watch the knock sensors and they will tell me when I have hit the saturation point.
    How do I know when my engine has too much timing at any/ all rpms
  8. #28
    Jan 2016
    Thank you for the reply. Do you have any idea on how I will know when I have hit too much timing (at any given rpm) other then noise and smoke. Is there any parms (like a knock sensor) that I can watch as an indicator?
  9. #29
    Aug 2008
    No there isn't. You will hear the timing/injector rattle very distinctly. If you run the tune through the program calculator you can see where stock items fall. There is tremendous range in the stock tune. A performance tune won't resemble that.
  10. #30
    Nov 2010
    If your using stock pulse and you begin to add timing, smoke will be a byproduct of too much timing. Remember that pilot timing is based off of main timing. So as you increase main, pilot also increases.
    As for top end fueling timing, with a re-entrant piston, 50% BTDC is ok with stock pulse...start going over stock pulse, you'll need to advance your split.
    If you have access to a load cell dyno..that would be your best friend.
    With diesels, no knock sensors, so you have 3-potential ways to find max timing...
    1. Dyno
    2. Track
    3. Calculated timing
    Les Szmidt
    2007 5.9 Dodge Ram
  1. auto VVE for stock engine ! ?
    By Ls1_Rulz in forum E37, E38 & E67 PFI ECM's
    Last Post: January 3rd, 2013, 09:34 AM
  2. Not getting maximum duration?
    By 2006Cummins in forum Cummins 5.9L
    Last Post: January 5th, 2012, 10:31 AM
  3. Looking for some data from a stock engine log
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: June 24th, 2008, 04:14 AM
  4. Maximum VSS value?
    By jsttry in forum General
    Last Post: December 30th, 2006, 11:42 PM
  5. Tuning a stock engine...Worth it?
    By CGTMS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 20th, 2006, 11:21 AM
