Page 2 of 44 FirstFirst 123412 ... LastLast
Results 11 to 20 of 437
Thread: Head Cam Intake ls1 2002 trans am
    Nov 2013
    It's only 140 bucks for the ls2(Correction:LC2). I understand how it feels like cost escalates, but the Wbo2 is one of the best things to get besides efilive. It comes with a weld on bung, so I mounted move on the driver side about two inches behind my regular 02s.
    That being said, there are definitely people who have tuned part throttle on the STFTs, I think if you search "narrow band tuning" that should hit it. So got to do wot tuning though which narrows can't help with.
    Timing jumping at idle is most likely due to active idle tables. Ecm is constantly trying to maintain the set rpm, but if your rpm is set too high or the range of spark is allowed to cycle too far then it will jump. When I get to my laptop I'll take a look at the maps that I altered for the idle timing, when I get to my laptop I'll take a look at the maps that I altered for the timing, every time I've responded I've been on my phone.
    Last edited by Jetmech442; February 9th, 2016 at 05:04 AM. Reason: corrected wb02 name
    Feb 2016
    Thanks that would be awesome! and where did you find it for 140 bucks? I couldn't find it for under 300.
    Nov 2013
    Look for the l"C"2,not the "M",the M just comes with stuff that efilive does for you already
    Feb 2016
    Oh, found it. I will buy that soon. Do i need to drill into the exhaust to put that bad boy in?
    Nov 2013
    yup. and it comes with a buing to weld in. I've also seen clamps with a bung, so you don't need to weld. you will also need to stop by Radio Schak and grab a "null wire modem connector". Check oiut Post #56 for pics and details. http://ls1tech.com/forums/conversion...version-3.html
    That connector allows you to just plug in your wb to the V2 and start grabbing data. I tried using the analog connectors to avoid 20$ on the adapter...it was two weeks of wasted time...
    I tried opening you tune when I got to work this morning and got rejected cause I must not have updated to the very latest software yet. I'll take a look tomorrow unless someone else gets to it first.
    Feb 2016
    Man I really appreciate all the great feedback you are giving me! I will look into this and hopefully have a wideband installed next time I go home so I can log some actual data while driving.
    Also:
    - B3609: set this to 0.050 s.
    - B3809: change this to more effective use fuel trim cells (for example, set it to 1500, 2500, 3500 rpm).
    - B4105: set this to 450 mV.
    - B0701: do you have cats...?
    - B0501: do you have EVAP system...?
    so you have manual trans...?
    Feb 2016
    I do not have cats and I still have my EVAP system. I also have a manual trans. I will make those changes. Also do I need to have the V2 attached to my computer in order to change the tune? Every time I try to adjust the tune it goes into demo mode and I still have my information for the device registered.
  9. #19
    Nov 2013
    Yeah it's gotta be plugged in. Once you mail in the blue card efilive sends you the authorization code so you don't need to anymore.
  10. #20
    You do not need V2 to be plugged into your PC/laptop to use the tunetool to edit tune files...
    did you enter the software user license details from the blue card into the Help->Register EFILive screen...?
    Do Help->Register EFILive and post a screenshot, it should look like this with the fields filled in correctly:
Name:	2016-02-09 08_59_03-License Manager.png
  1. B8010 Intake Cam Filter
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: October 6th, 2013, 04:11 AM
  2. Bad MAF calibration post Head/Cam swap - help?
    By bimbleuk in forum Gen III V8 Specific
    Last Post: July 25th, 2013, 07:44 PM
  3. Problem with my Head/Cam 98 LS1 camaro - files attached
    By blackflag in forum Gen III V8 Specific
    Last Post: May 10th, 2011, 05:27 PM
  4. 2000 Camaro Head and cam tune file.
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2007, 11:10 AM
  5. A question for you head and cam guys.
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 07:12 AM
