From an engineering standpoint, 234 is fine as long as you have the right mixture and a working pressure cap. That being said, a lot of people, including myself, run lower. I prefer 200-210 F only because if something does start to overheat I have time to react.
A quick search on ls1tech will reveal the entire spread of pinions on this. So I'll just say that the above is my opinion.
Sent from my Nexus 6P using Tapatalk
But I shouldn't worry about engine damage from the quick flirt to 234 ECT?
Just changed it so that both are on by 208 ECT
I've had mine up to 245 a couple times accidentally when the fan relay kept blowing and no issues.
I'm in the garage right now, but take a look at when your "hot engine protection" tables kick in. These tables kick in before damage occurs in an attempt to protect. Pretty sure you'll find 234 is within that limit.
I feel like I'm being a little lax. Let me be clear, I don't ever like being up in the 230s, ever. I get real nervous up there because I only ever get to 217 if something has failed .but I'm just saying it's not causing any physical damage at that temp.
I use these Fan temp settings:
G0901: 206
G0902: 199
G9013: 214
G0914: 207
ok good, there is some peace of mind right there! I think I find at least one source of the vacuum leak which is the throttle body attaching to the intake and some possible interference with the water pump. I will keep yall posted!
