Highlight of my week!
Oreo,
In my engineering opinion, evenly slaved ltft frame ending under 3000rpm should be ideal. However, SSpeedemon had a tune out there that covered up to like 6000 rpm. He had his reasons, and looking at single maps doesn't tell the whole story, so it may or may not work for someone else. This is the danger of finding tunes and trying to piece wise implement them(talking about me here, not you...) .
NB02S are great around stoich. Using them for part throttle stuff is best. To eliminate the effect of a dead 02 and this a dead ltft, go into the clcxxx and replace the ltftben"dead"with the active one. The formula is (ltft1+ltft2) /200 +1 if I remember right(still at work sorry).
Now rerun calc. Vet and you should see meaningful change
Sent from my Nexus 6P using Tapatalk
CLC-00-120 is the Pid to modify...
If you're suspecting NBO2 problems, then remove them and use WO2BEN.
How do I make sure that the CL/LTFT/STFT/SOL are disabled? Do i do that within in the tune itself?
Also, I made the change
*CLC-00-220
factor 0.5 1.5 .4 "iff({CALC.CL}, {CALC.WO2BEN}, {CALC.WO2BEN})"
Is this the only change I need to make to not use the stock narrow band O2 sensors?
B3801 LTFT disable
B4108 STFT Idle disable
B4205 CL disable
I'm not sure what SOL is (Semi-Open Loop)?
I think the reason Joecar is recommending this is cause you will be using the CALC.WB02BEN = {GM.EQIVRATIO}*{EXT.WO2LAM1} and GM.EQIVRATIO doesn't account for all the STFT/LTFT adders.
If you want to keep everything as is, then just paste this in place of *CLC 00 120 in the calc_pid.txt file.
*CLC-00-120
factor 0.5 1.5 .4 "({SAE.LONGFT1}+{SAE.LONGFT1})/200+1" ***I haven't seen a recent log with LTFTs working, so make sure LTFT1 is the one that's actually working. If not replace the SAE.LONG"1" with a "2" for both spaces.
Modifying that pid will be making corrections to your CL part throttle VE map based on just one side of your engine. I prefer this way because of the accuracy of the NB02's around stoich.
