Originally Posted by
oreobadr
What I decided to do was use CALC MAFT and compute my VE values with no MAF. I will be doing this calculation with only using my wideband sensor.
What should I do to my CALC PID file from before? would it be the same as my calc vet PID file?
Calc.MAFT does this:
1. it corrects the VE table;
2. it calculates a MAF table based on 1. above, but it requires the MAF to be installed because you need MAFFREQ in order to be able to create a MAF table.
So, yes, Calc.MAFT is done in SD (and certainly in OLSD, see OL note below), but your MAF must be present (and disabled in the tune so it causes a MAF DTC), and you log MAFFREQ from it.
OL: to do Calc.MAFT or Calc.VET in OL (i.e. using WB only), edit CLC-00-220 to always select CALC.WO2BEN as follows:
change this:
Code:
*CLC-00-220
factor 0.5 1.5 .4 "iff({CALC.CL}, {CALC.LTFTBEN}, {CALC.WO2BEN})"
to this:
Code:
*CLC-00-220
factor 0.5 1.5 .4 "iff(0, {CALC.LTFTBEN}, {CALC.WO2BEN})"
the 0 is a zero.
Yes, it is the same calc_pids.txt file (I made it that way on purpose).
