Results 1 to 10 of 12
Thread: 08 Suburban VVE and MAF maps/pids HELP!
    Lifetime Member picnic_george's Avatar
    Jan 2007
    Default 08 Suburban VVE and MAF maps/pids HELP!
    Here is a tune and a log I took of a suburban. I got part of the VVE better using the STFT but for some reason I don't know what PID(s) to log and/or if there is a BEN for it. I have BEN from serial WB (CALC.WO2BEN) but it says the expression is {GM.EQIVRATIO}*{EXT.WO2LAM1} but {GM.EQIVRATIO} is not a valid PID.
    I'd also like to read the MAF BEN factor in the same way.
    Forgive my ignorance, it's been a while on efilive with anything other than my trans am, and this is my first time messing with an e38 computer on efilive.
    Kris
    Jan 2007
    Think I got the calc.pid figured out
    *CLC-00-445
    factor 10.00 20.00 .1 "{EXT.WO2AFR1}/{E38.AFRATIO_DMA}
    CALC.WO2BEN_E38 F445 CLC-00-445 factor Tuning "BEN from Serial WB E38"
    Looking at the log it seems legit
    Now to figure out the MAF, looks as if my BEN wants MAF frequency but that PID isn't available, it only offers a lbs/grams PID
    Edit- Looks like I can log GM.MAFFREQ2 so I'll try that and see what happens.
    Also try "{EXT.WO2LAM1}/{SAE.LAMBDA}"... add an new calc pid for it (to compare with your pid above).
    Yes, correct, try logging GM.MAFFREQ2.
    Jan 2007
    I'll try that and compare the results. Probably better since it's s flec fuel car.
    Jan 2007
    They matched Joe, thanks. And the MAF pid worked as well.
    Question I've done some changes to the idle tables and got it to idle really well, not surge or push on the converter.
    But it has a hot start issue. It starts fine cold but when it's hot you have to apply a little throttle for it to get running. What setting should I be looking at? I could post the tune I'm working on now but I'm not at my laptop and the original tune posted had the same issue. I added starting RPM in P/N and Drive to more match what I have the RPM set to but that didn't help.
    Thanks for the help/
    I'm thinking it thru in my mind...
    Would it be table B1602...?
    Jan 2007
    I'll take a look when I get to my laptop.
    It's weird it only does it warm/hot. It's like it tries to start first time then nothing, just turns over. I just find it awkward that adding a little throttle to a TBW car would even do anything while cranking.
    Yes, it should not require any throttle input from you.
    Also look at the lower corner of the VVE table.
    Jan 2007
    What should I be looking for? Should I log during cranking and see where it is and adjust those cells? At idle the ltfts even out to about -2% +-
  1. MAF wont fail for VVE tuning
    By 2007chevy5.3l in forum E37, E38 & E67 PFI ECM's
    Last Post: July 25th, 2013, 06:20 AM
  2. Help with pids and maps
    By zbadestz in forum FlashScan V2 BB Logging
    Last Post: April 19th, 2012, 09:55 AM
  3. Correct pids for VVE tuning
    By 68problemchild in forum Gen IV V8 Specific
    Last Post: December 13th, 2010, 03:48 AM
  4. Tuning MAF vs VVE
    By minytrker in forum E37, E38 & E67 PFI ECM's
    Last Post: August 27th, 2009, 12:29 PM
  5. Maps and pids....
    By SSpdDmon in forum General
    Last Post: July 11th, 2007, 05:09 AM
