So i got my car back today and i tryed my efilive out and i can't connect. I plug everything up, turn the car to the on position and try to "connect" and it gives me a error code ERR_NOCABLE/31 No Interface cable found. I reconnect everything and it gives me the same message. the usb port works because when i installed the software it saw the cable so i could install the flashscan drivers. and the obd and usb lights flash on the cable when i hook it up to the car. and i had my buddy hook up one of their scaners at work to see if my obdII plug on my car was good and it worked. Any help is appreciated.
thanks
-mark
