Results 1 to 5 of 5
Thread: Cummins ignition problems
    Feb 2016
    Default Cummins ignition problems
    Does anybody of you here ever faced 2007 dodge cummins 5.9 problems with the ignition. That was dangerous. The ignition shuts down suddenly when we drive, without any signs, then we will lose the power steering and control. I experienced this issue two times. What can I do to resolve this issue. I can not afford another truck at this time. So I want to clear this issue soon.I need a permanent solution.
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    Most likely you have a skim module or key going bad. That is as long as your truck is not an st trim level. If you have a spare factory key try using that key. Otherwise the skim module is a likely cause. I would suggest checking on some of the dodge/cummins specific forums for more info. This forum is dedicated to the tuning side and not troubleshooting/repair topics.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    May 2010
    I have had this happen to my truck a couple of times as well. My looking into it lead me to checking and cleaning all ground connections. I went over all of them i could find. I do not know if that solved it for sure but i haven't had it happen again in several months. If it happens again i will take anarchys advice and look into skim module/key problem.
    So is the SKIM system constantly checking or just on start up? Normally on anti-theft systems once they have passed the checks at startup that is it they don't continue to validate the codes....but I am thinking GM here, not 100% on Dodge.
    Jun 2011
    I cannot say that it is constantly checking, but for sure if the skim goes offline on the can bus it kills the ignition signal to the ecm.
    423-506-7427
  1. 2012 cummins ecm flash $0549a, key not in ignition
    By jkholder09 in forum Cummins 6.7L
    Last Post: March 15th, 2015, 04:04 PM
  2. Replies: 15
    Last Post: October 29th, 2013, 04:22 PM
  3. pre-ignition
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: November 30th, 2008, 11:55 PM
  4. Ignition welcome message
    By stigmundfreud in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2008, 11:39 AM
  5. Ignition Timing
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: May 30th, 2006, 03:47 AM
