Results 1 to 2 of 2
Thread: Help setting up serial logging into v7.5 scanner
    Aug 2015
    Default Help setting up serial logging into v7.5 scanner
    Like the title says we have tried over and over to get this thing logging with the serial output from the lc2. We have a cable from the out on the lc2-null modem adaptor- cable from there to the rj12 input onthe v2 box. I think we have everything setup right from hours of searching and on here and still nothing. Somebody please guide us right
    Here's a thread specifically about LC-2: LC-2-Digital-Wideband-anyone-try-it-out'
    I see you have a null modem adapter, so check your wiring, see post #38 in that thread.'
    Are you plugged into a powered-up OBD-2 port connected to a PCM/ECM...?
  1. Setting up Serial WB to work with Auto VE tutorial.
    By jmsmotorsport in forum Tutorials
    Last Post: January 15th, 2016, 08:42 AM
  2. Newb Setting up serial Wide band
    By HellKnightHicks in forum General
    Last Post: January 16th, 2013, 11:30 AM
  3. Serial logging and tuning with 2 LC-1's
    By truethinker in forum External A/D inputs
    Last Post: July 9th, 2012, 02:11 PM
  4. Setting up auto ve with serial input ???
    By Slowrc in forum Gen III V8 Specific
    Last Post: February 12th, 2010, 04:01 AM
  5. Need Help w/LC1 Serial Logging
    By TFZ_Z06 in forum FlashScan V2 BB Logging
    Last Post: August 4th, 2008, 02:35 PM
