Results 1 to 7 of 7
Thread: Low rail pressure
    Senior Member garrettg.bpd's Avatar
    Jun 2013
    Default Low rail pressure
    Im fighting lower fuel pressure on a 07.5 6.7. The rail pressure drops off after 2000 rpm on a stock tune. The turcks history is unknown for sure. The used car lot said that it had "upgraded injectors" and that the fuel filter had been changed. On my inspection i found that the fca is new and a rail plug was installed. Retorquing the rail plug help a little. So it was replace with a new releaf valve that i shimed with no change in top end fuel pressure. Any insight would be great thanks. Click image for larger version.
    EFILive Beta Tester
    2006 DODGE RAM 2500 4X4 Industrial Injection R1 100HP Injectors and BAG-O-PARTS, ATS Exhaust Manifold, AFE 67MM Turbo and MANIFOLD
    Nov 2010
    I vote dead pump
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jun 2013
    Cp3 or lift
    EFILive Beta Tester
    Jun 2013
    Stock lift pump. If unpulg the fca fuel pressure will max at 29k. Tuning the fca has little to no change.
    EFILive Beta Tester
    Nov 2010
    Id say cp3..pulling the fca at idle won't tell you much other than you don't have a HPR leak...the fact that fca goes 19mA with a 16-1700uS pulse...in my experience is a very weak cp3
    Les Szmidt
    2007 5.9 Dodge Ram
    Mar 2012
    had a rash of these the past year, screen at base of fuel pump plugged, cleaned screen and good to go
    Dec 2012
    Hey guys, Just figured I could update this post.
    This is my truck Garrett was working on. The CP3 failed around 10/16. We pulled the truck apart and did a pretty major overhaul. Turns out the Injectors were R1 units from I.I. The cp3 was a factory pump and just couldn't keep up. We put an 85% over cp3 and R2 Injectors on, along with milling the intake manifold off, and replacing with a b&b tooling one. Truck runs great now.. The factory turbo won't push much over 30 psi because the restriction removed from the system.. also the trans. isn't too happy with all the new power... ITS ALWAYS SOMETHING!!!!
  1. Low Rail Pressure, Tune or Truck?
    By Wheelz in forum Cummins 6.7L
    Last Post: September 30th, 2013, 12:10 PM
  2. Rail Pressure
    By mstordahl in forum Cummins 5.9L
    Last Post: June 11th, 2012, 11:27 PM
  3. low fuel rail pressure
    By joev4628 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 23rd, 2011, 03:50 PM
  4. Low fuel rail code P0087
    By Tarkstoys in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 6th, 2011, 07:15 AM
  5. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
Tags for this Thread
