Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Cannot Purchase New Vin License - No Auth Code
    Feb 2016
    Default Cannot Purchase New Vin License - No Auth Code
    I received a V2 that the owner stated they had used both VIN licenses and I would need to purchase another one. Cool, not a problem. I checked online how to do it, see that I need the serial and auth code, gotcha. I can get the serial, however in the VINs tab it doesn't give me an auth code, so I'm not sure how to go about purchasing another VIN license.
    Any assistance?
    EDIT: To add, when attempting to do any sort of flashing on the PCM, it gives me error $0533, No Vin License Slots Available which is technically correct, however it is not in any way, shape, or form giving me the option to purchase a new license because it does not seem to want to give me an auth code.
    Follow this and see if it helps you ;-)
    https://support.efilive.com/kb_artic...2143-YUOG-8049
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    Feb 2016
    Quote Originally Posted by Happy Jim View Post
    Jim
    Yeah, that was the very first thing I was following. The Auth Code field in the VINs dialog literally says "N/A" and the VINs dialog only shows the 2 licenses that have already been used by the previous owner. To note, this does have the GM tuning option activated.
    Did you get this sorted out...?
    Feb 2016
    No :( any help?
    Quote Originally Posted by tenpaiyomi View Post
    Can you post a screenshot of this
    ( see post #1: Hosting-an-Image )
    Feb 2016
    Unfortunately I just left out of town till Thursday for work. I'll grab a screenshot and mock up what my view looks like, give me just a few minutes.
    Can you generate a license backup file (*.lbu) of your V2? To do that, select the [F7 Licenses]->[Backup] option.
    Then email the *.lbu file to me at paul@efilive.com with a link to this thread.
    Just for your interest the Auth Code field will show "N/A" under the following conditions:
    • If the FlashScan device is busy performing other tasks (such as read, flashing or logging data).
    • If a device is not selected in the lower right corner of the main EFILive V8 window.
    • If the device's serial number is less than 12 digits long.
    Is it possible one of those is true?
    Feb 2016
    Paul:
    1) Not likely, it's just sitting there doing nothing
    2) I wouldn't think so, I wouldn't expect it to be able to show the 2 redeemed licenses unless the flashscan was selected
    3) 003669970871
    Feb 2016
    This is what it generally looks like, for what it's worth. A quick photoshop since I don't have access to my FlashScan V2 again till Thurs.
Name:	Photo Feb 15, 8 47 40 PM.jpg
  1. Replies: 2
    Last Post: December 31st, 2012, 11:11 PM
  2. Replies: 7
    Last Post: December 31st, 2012, 11:52 AM
  3. 45 Minutes Has Passed, Still No VIN License Activation Code?!
    By n8dogg in forum Purchase and Shipping
    Last Post: June 1st, 2012, 10:30 AM
  4. Newbie with v2! need help finding auth. code....says N/A...
    By duramax_freak69 in forum FlashScan V2
    Last Post: February 27th, 2011, 07:20 PM
  5. Invalid Auth. code?
    By algz06 in forum FlashScan V2
    Last Post: April 18th, 2010, 09:15 AM
