Results 1 to 8 of 8
Thread: A40 vs A46/T14A
    Jul 2008
    Default A40 vs A46/T14A
    A40 OSes are incompatible with A46 hardware (and vice versa). 06-08 pickups all have both A40- and A46-specific cals, but no A46 cals exist for MD trucks. what is someone supposed to do for a new replacement TCM for an 06-08 MD truck now that A40s are discontinued?
    We have not seen an A46/T14A to know if they will even work in the software, when did the A40 get replaced?
    Jul 2008
    probably around same time T14 came out, i.e., ~2010, maybe later? new A40s were still around for a while but good luck ordering a new one now. T14A = # 24256864. integrated bootloader. it's a Delco branded A46 with some default GM OS. i'm just wondering what people do when buying a new TCM for an MD truck, because A46 won't work and (afaik) new A40s are not available anymore.
    Jan 2006
    Quote Originally Posted by vectorbundle View Post
    I have stock of each, both used and new.
    Custom Tuning Services
    Jul 2008
    Quote Originally Posted by killerbee View Post
    so do i. for now. problem with new A40s is they will eventually be unobtainable. gonna have to figure out how to set up T14As with a MD cals. i have an idea how to do it. but no trickery should be necessary. there should be a standard OEM procedure for installing/programming a new TCM replacement in an 06-08 MD truck, with something other than discontinued A40. if there is, i can't get any info on it.
    Nov 2005
    Have you checked/can you confirm that they are a drop in replacement? and they work with the current software?
    Cheers
    Cindy
    Jul 2008
    they are, for pickups. i don't know what to do with MD cals yet, they only have A40 OSes available afai can tell.
    i did a full read of some A46 pickup cals with EFIlive w/o issues other than some OS checksums come up as invalid. i can send some files over if you like.
    Nov 2005
    I think that the A40 full read option may throw invalid checksums, so perhaps the A46 is no different.
    Can you please try a cal read? and send through both read files to cindy@efilive.com
    Cheers
    Cindy
  1. A50 to A40 swap???!?
    By rfinn04 in forum Allison 5 & 6 Speed
    Last Post: November 23rd, 2014, 03:25 PM
  2. A40 full read?
    By vectorbundle in forum Allison 5 & 6 Speed
    Last Post: November 6th, 2014, 08:02 AM
  3. A40 Schematics
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 5th, 2007, 12:20 PM
