Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 55 chev LS3 conversion E40 T42 mph problems
  1. #11
    Feb 2008
    Post your current file please
    Cal Editor aka A.J.
    Lead Calibrator at PCM Calibrators
    ASE Master Certified since 1988 -- ASE L1, F1 & A9
    GM Technician since 1999 -- GM World Class Technician since 2009
    CNG Installer -- CSA Inspector
    A handful of people out there who do have an intimate knowledge of GM Calibrations
  2. #12
    Feb 2008
    It looks like you need to get the correct sensor also
    Cal Editor aka A.J.
  3. #13
    Feb 2016
    I installed corvette speed sensor with no change.
    I have installed operating system and calibration from my wife's 2006 SS Trailblazer this morn, speedo reads within 6 miles or so now.
    Now I will Start tuning on TCM again.
    Here is current tune.
    Don06TBTCM.ctz
    Any suggestion on what to change would be great, this is my first time.
  4. #14
    Feb 2008
    The Corvette speed sensor placement is in the rear diff and the reluctor ring is incorporated into the outside area of the ring gear. The reluctor spins at the same speed as the wheels.
    On a Camaro or truck the VSS in at the end of the trans and spins at drive shaft speed, before the rear diff.
    Bryan says you have a 4L80 trans is this correct?
    I would built out the trans calibration to match the trans used.
    The engine calibration needs to be setup correctly as a non Corvette application using a Corvette or SSR/T-blazer SS file
    As you can see the VSS is setup for a Corvette.
    Cal Editor aka A.J.
  5. #15
    Feb 2016
    4L65e Trans
    Im getting P0723 with the corvette sensor, reinstalling Camaro sensor now to see if code goes away
  6. #16
    Feb 2008
    Quote Originally Posted by AutoRehab View Post
    4L65e Trans
    if the sensor is not on the rear diff and is in the trans it needs to be a Camaro type. Bryan did not mention that this was in a 55 chev. If you have a 4l65 then I would just run the T-blaser SS calibration as a base file
    Cal Editor aka A.J.
  1. Chev/Holden 1.4L Cruze E85 FlexFuel Conversion
    By GMPX in forum E78, E83, E84 PFI ECM's
    Last Post: October 15th, 2014, 08:58 AM
  2. E40 LS2 GTO adjustments for LS3/LS7 MAF sensor conversion
    By ACCLR8N in forum Gen IV V8 Specific
    Last Post: January 9th, 2014, 04:00 PM
  3. T42/E40 Logging
    By Webbs in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 8th, 2013, 06:43 PM
  4. 05 Hummer/55 Chev conversion..
    By Chuck L. in forum Conversions / Aftermarket Parts
    Last Post: June 8th, 2011, 03:45 AM
  5. KMPH to MPH conversion
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: February 22nd, 2006, 03:09 AM
