Results 1 to 9 of 9
Thread: BBX Sub pids
    Aug 2011
    Default BBX Sub pids
    Looking at monitoring my STFT and looking at the bbx screen, it lists sub pids when i select the main O2 pid. Are the sub pids automatically added or is it just saying it needs those pids added manually as well to work?
    Oct 2015
    The Sub-pids will be added automatically when you add the primary/main PID
    Aug 2011
    just wondering as it didn't count sub pids towards the pid count at the bottom of the bbx screen
    Oct 2015
    You should be able to confirm by looking at the bottom left hand corner in the Selected PIDs screen afterwards.
    The pids O2SxxV are "compound" pids.
    I prefer logging HO2Sxx and SHRTFTx instead.
    Aug 2011
    What is a compound pid? and why is it not preferred? also for the ls1b it lists a maximum of 24 pids, is this a recommended max for logging speed? or something else?
    "compund" pid (sorry, I couldn't think of a better term) is the pid with multiple field content, e.g. the pid O2S11V contains both O2 voltage and SHRTFT.
    You can log it and use it... it occupies 2 pid channels (the separate pids HO2S11 and SHRTFT1 each occupy 1 pid channel, so it's the same).
    I prefer (it's my preference) to have the pids separate because there are logs where I want something else instead of SHRTFT.
    Aug 2011
    What about the 24 pid limit? is it a hard limit or a recommended limit for logging speed?
    Quote Originally Posted by cyipher View Post
    The 24 pid channel count is not a limit, but a recommendation to achieve the fastest logging frame rate...
    ( most pids occupy 1 pid channel, some occupy 2, and some 4 )
    in Stream-Fast mode logging from an LS1B PCM:
    1 to 24 pid channels logs at 10 frames/s
    25 to 48 pid channels logs at 5 frames/s
    ( a frame containing all the pids selected for logging )
    see scantool user manual pdf Appendix E "Scan Modes".
  1. Do I need CSP5 to BBx
    By Ghostman in forum Cummins 5.9L
    Last Post: December 24th, 2015, 03:51 PM
  2. Pids not showing up in scan for the diesel motors in the bbx
    By Scarface in forum FlashScan V2 BB Logging
    Last Post: April 9th, 2014, 03:48 AM
  3. Help with bbx
    By restless@westnet.com.au in forum Black Box Logging
    Last Post: May 27th, 2013, 04:48 PM
  4. Bbx and pids
    By Harrismarine in forum Black Box Logging
    Last Post: September 5th, 2012, 11:59 AM
  5. BBx troubles
    By jollyrogr in forum Diesel
    Last Post: August 8th, 2011, 05:09 AM
