When doing SOL do the fuel trims show up when logging STFT's? or do STFT's need to be enabled to watch them?
When running a COS, STFT's show up to do SOL... usually the OL STFT Enable parameter is missing from a COS, but if it is present and disabled, SOL overrides it;
i.e. STFT's come into play for SOL or OL STFT or both modes (of course, only on B3647/B3605 cells that are stoich, i.e. EQR 1).
so if im logging stft and sol is active, stft's will show some activity on the scan tool regardless if stft is enabled, correct?
And at what temp does SOL enable at?
