Results 1 to 10 of 10
Thread: File synching
    Oct 2005
    Default File synching
    Looking for an application that automatically synchs files (tune, logs, notes)between my laptop, home desktop, and work desktop. What are you using?
    97 Vette 6spd, CamMotion Titan2 LS1 cam, TSP 5.3 StageII heads, Vararam intake, Z06 manifold, ARH headers/cats, Z06 catback, Monster Stage2 clutch, 04 Z06 pcv, new style knock sensor(late98 to 04).
    Using FlashScan V1 with NGK-AFX Wide band
    OneDrive, DropBox, or Google Drive would be my go-to apps.
    Lifetime Member Mitco39's Avatar
    Jan 2009
    I tried the file syncing approach, got upset with it and went out and got a laptop extender and just run one laptop that I can turn into what is essentially a desktop when I am in the house/shop.
    I copy important files to/from a huge USB fob
    ( I was not happy with file syncing solutions )
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    dropbox
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Dec 2005
    4TB dual cloud drive is what I use. Sits in a climate controlled safe connected with an Ethernet cable.
    www.mscservices.net
    Lifetime Member Chavez91's Avatar
    Dec 2012
    I got Google Drive with Unlimited Data. Works great for me.
    Josh
    '04 GMC LLY
    - L5P, Motech, 6-Spd Conv. ML Trans.
    '05 GMC LLY - 250%, 12mm, 67mm Custom Turbo, 6-Spd Conv. ML Trans
    '19 3500 RAM - Tuned Aisin 0_o
    Dec 2005
    The only cloud I like is one that nobody has access to and is off the grid
    www.mscservices.net
    Dec 2012
    Touche'. Thats why I made a 250TB server at the house for the security cameras and all my nightly data backups of the stuff I dont want to be accessible. Drive works good for just keeping an updated stock library of tunes that accessible between all my devices so If im on the road and run into someone needing a tune, I have what I need to make one on the spot. But Scrpits and all customer tunes and data stay at home on the server.
    but that climate controlled safe. ;] that sounds pretty nifty. I keep mine hidden in a remote part of the house but have the entire system liquid cooled which works great.
    Josh
    '04 GMC LLY
    Quote Originally Posted by GMC-2002-Dmax View Post
    +1 ×2
