Results 1 to 3 of 3
Thread: Issues
    Aug 2015
    Default Issues
    so my v2 decided have a hissy fit, i try to use bbx and i get code $0183 and go into efi live explorer and get error $0185. i tried using another v2 and it works fine. what did i do? and how do i fix?
    thanks in advance
    From the Error pdf:
    $0182
    F_ERR_NOTFORMATTED
    The target file system (CONFIG or DATA) is not formatted.
    Format the appropriate file system.
    DATA: Use the onboard setup tools format the DATA file system on both the SD card and the internal memory.
    CONFIG: Use EFILive_Explorer to format the CONFIG file system.
    $0185
    F_ERR_NOTFOUND
    A file or folder was not found.
    You may need to copy a required file to FlashScan or AutoCal using EFILive_Explorer.
    Or you may need to format the target file system, see description for error $0182 above.
    Do you have an SD card...?
    What V2 firmware version (start V8 S&T and you will see it there)...?
  1. ETC issues
    By GMCtrk in forum General
    Last Post: September 25th, 2011, 04:32 PM
  2. A/C issues
    By Naf in forum Gen III V8 Specific
    Last Post: June 14th, 2009, 11:07 PM
  3. Issues with 7.51
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: December 17th, 2007, 04:44 PM
  4. Known issues in V7.1.16
    By Blacky in forum General (Petrol, Gas, Ethanol)
    Last Post: January 24th, 2005, 04:21 PM
