I have auto tune loaded and manual loaded for comparison but the copy segment option is greyed out. What am I doing wrong?
I don't think LS1A allows segment swap.
Post screenshots.
I just used a 98 tune with manual trans from the Depot. As for screenshot the menu option for 'copy segment' was just greyed out even with cal loaded. Same os of course.
GMPX, I have a question regarding this if you can take a minute to look it up. I know your busy
Is this something that was never finished?
I noticed when you open an LS1A File it only shows an engine calibration. No other info regarding segments.
Also the H0103 for the gear ratio/ final drive is not populated and is set by EFI live to 0. There for you can not use the calculator when changing gear ratios.
I find it odd that the old 98 Black box PCM has this info populated but not the LS1A PCM's.
I don't expect you to drop everything and fix it, I am just curious why that 1 specific application does not have that table populated as well as why it does not display the other segments.
