Results 1 to 4 of 4
Thread: Lbz injector replace with 24lpm injectors
    Feb 2012
    Default Lbz injector replace with 24lpm injectors
    Looking for some help in tuning my lbz Im replacing srock injectors with 24lpm injectors balanced to 1% they are approx 26.5 % over stock
    I've never tuned bigger injectors and looking for a place to start.
    Truck currently is stock with airdog 165 4G and 4 inch exhaust.
    Apr 2014
    what other supporting mods do you have besides what u mentioned? and what u use the truck for?
    Mar 2009
    For that small of an injector, you really don't need to change anything. It should run fine with a stock tune in it. You wouldn't require but a small pulsewidth change to bring it back in line with stock, and stock timing should be fine.
    Dec 2013
    Whos injectors? If they were balanced to 1% is that just the nozzle static flow or dynamic flow chart? And if so, can injector supplier provide you with a flow chart?
  1. Using LBZ injectors and pcm on detroit diesel
    By boothybunch in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 3rd, 2014, 04:20 PM
  2. (B3701) Injector Pulse Width values for SVO 42# Injectors
    By DrkPhx in forum General (Petrol, Gas, Ethanol)
    Last Post: September 13th, 2009, 02:56 AM
  3. Injector Offset for #83 lb/hr injectors
    By turbo_bu in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2009, 04:01 AM
  4. Determining injector size without knowing where the injectors came from?
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: August 22nd, 2007, 11:51 PM
  5. Injector flow rate with 96 lb injectors??
    Last Post: September 9th, 2005, 06:40 PM
