I'm thinking about buying a used copy of EfiLive/cable, but it has the 2 slots filled up. The slots are for a Camaro and I've got a Corvette. What would I have to do in order to use/register this software, and would it work for my car?
All you have to do is buy more licenses from here
http://www.efilive.com/pc-39-15-flas...m-licence.aspx
You can put up to 25 licenses on a V1 cable. Each license is PCM locked, so will only work on THAT PCM. They cost $99 each. The licenses are good for any vehicle the EFILive supports.
Make sure you get the blue registration card with the cable so when you download the latest software, you can input the registration and it will recognize it as the full version of the software and not just the demo.
Oh, and I forgot to add, that if your Corvette is a 97 or 98, then you don't need to buy any licenses, as they are FREE with EFILive.
Thanks ALOT Kbracing96! I appreciate the help!
