Just a question about this, If I tune on a stock pump and then switch to a 255 walbro with the hotwire kit will I have to retune my car?
Data log before and after. Then compare the results
I got it all working and the wb02 logging data as ithe should. One thing I have noticed is when I have made adjustments to maf and b0101 the engine wants to hunt for idle coming down off light/medium throttle. I have gone through the sspeedemons idle tutorial. I probably just need to go through the idle tutorial again to straighten it out. Does the calcvet method work on the newer computers? Like the e38 computers?
Calc.VET does not work on E38, take a look at the VVE table, typical values range from 500-2500 (IDK what units)...
it can be used to correct the MAF, but I'm not sure how to handle VVE yet...
I'm working on it tho.
