Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Any Advantage to Lowering Minimum Pilot to Main and Main to Post Time?
  1. #11
    Dec 2013
    OK, so at the risk of talking in circles.
    What Ghostman and myself are talking about. Those parameters you screenshotted are limiters. You said you are not running into any limiters in a previous post. So at that point I posted that you answered your own question because you told us you are not running into these limiters.
    So then at that point I asked if you are talking about tuning theory moving injections that close together to where the limiters would matter? Or the parameters themselves.
    They don't move your injections closer together by changing these values unless your tune is running into it and they are holding you back.
  2. #12
    Lifetime Member Move'n Up's Avatar
    Oct 2015
    Quote Originally Posted by SASDakota View Post
    Okay, so I must be interpreting that minimum gap in time incorrectly?
    2006 Ram 2500 4x4, 5.9 CTD, Laramie, QC
    Fully Built 48RE, Billet Flex Plate, Triple Disc TC, 62/65 HE351cw
    2017 Corvette 3LZ Z06 M7 with Z07 Package
  3. #13
    Nov 2015
    I believe they function as a limiter. For instance, if you have your pilot a lot of pulse width and it was still commanding pilot up to 250 before the main event was to start it would cut the pilot off. If you adjusted to 100 it would let pilot continue to 100 and then cut it off.
  4. #14
    Dec 2013
    Basically what ghostman said. I had a big elaborate reply typed up on my phone and it erased it all... I said screw it.
    Basically one parameter ends pilot shot 250us before main shot will occur (main shot being the authority). And the other I think delays post shot until 600 us after main. I don't think it cuts main shot like it would cut pilot. Can't say for certain because I have not tested it.
  1. Main Injection vs. Main Injection (No Pilot)
    By WisconsinHick1 in forum General (Diesel)
    Last Post: April 7th, 2013, 06:04 AM
  2. RTACS on Main VE and Boost VE at the same time?
    By BlackGMC in forum RoadRunner Real-Time PCM Emulator
    Last Post: March 25th, 2013, 07:49 AM
  3. Pilot vs No Pilot Main Pulse Map
    By brossjd in forum Duramax LLY
    Last Post: August 7th, 2012, 10:41 AM
  4. LBZ Main Injection Pulse Time
    By JoshH in forum Diesel
    Last Post: May 10th, 2007, 10:04 PM
