Thank you two very much!! That cleared a lot up!!
99 ECSB 1500 6.0 lq9/243 2wd 3.42 in the works.
Efans - CAI - Walbro 255lph - Eaton LSD
BTR STAGE 3 truck cam - 60lb Inj - MP122HH
FLT Level 5 - 3000 SC YANK
Pacesetter LT's - ORY
13.170 @ 103.33 Mph -
So I managed to get a log done on this Tahoe. However after completing it I realized I have the tune file that's setup for autoVE. in it when I did the logging (via autove turtorial)
is that ok?
I will attach the log file plus the tune that I modified (autove_first log). I took the logged info and copied them over to B0101 and pasted with multipliers. The numbers are a pretty big change. ( probably because I copied the ve from a cammed lq9, its all I had to work with, tunefiledepot wouldn't download)
then smoothed the peaks out. I also logged the maf (tab B) those numbers where not off to far from what I noticed. even though its set to fail it still read info.
hoping I am doing this right. thank you for helping me out the other day and getting this going!
In your tune file, set these as follows:
B3608: 0.05 s
B3609: 0.05 s
B3616: 65% below 3200 rpm, 35% above 3200 rpm.
B3615: same as B3616 immediately above.
B3618: EQR 1.175 (the EQR 1.134 in B3605 is not rich enough for WOT).
C6001: set P0101, P0102, P0103 to A:1-Trip.
D0961, D0962: set to 100% everywhere (same as D0960).
If you're doing AutoVE or AutoMAF, then also disable B4206.
If you don't see enough digits after the decimal point (e.g. none at all), then highlight the cell and click the +.00 button until you see several decimal digits.
Is this the file where you applied the AutoVE (paste-multiplied the map)...?: 2005 tahoe ppv_6.0_autove_ first log.ctz
Disable B4206 and start again (throw that file away, flash in the previous file).
So how much should I change in the B3605 table? I changed some in the table as you can see. you think anything above 65 map KPA and about 176 degrees ECT should just be the 1.134 EQ Ratio? thank you again. Its making senseB3618: EQR 1.175 (the EQR 1.134 in B3605 is not rich enough for WOT).
so I got a start up log, however I got DTC p0054, p0060, p0300
rear 02 sensors and muiltiple misfires
no DTC for maf to do calc.vet
what am I missing
okay I got it figured out P0103 code
forgot to change hz to 1
